Some pics and a few ???.
Old Feb 14, 2007 | 05:20 PM
jetdoc's Avatar
jetdoc
Default Some pics and a few ???.
As you can see the smaller of the old snubbers is pretty much toast, and I hope it was worn enough to have caused my clanking when going into reverse.
You can also see the snubber is propped up against a metal sleeve, which was inserted in the old snubber. I tried to use it with the new one but to make a long story short it wouldn't work.
Do any of you guys know if the sleeve was part of the assy that came with the stock snubbers or if it shoud've been used in conjunction with my new one?
Also I had a leak from my thermostat housing. The prior owner said it was because he had a chrome housing and it would loosen up and he'd retighten the bolts and it was good to go.
I planned on using a rubber based gasket and doing a good job on sealing and installing it. When I removed the old housing, as you can see from the picture, the housing where the hose connects is warped. Im not sure if that would cause a leak but I am changing the housing regardless.
Old Feb 14, 2007 | 05:30 PM
Durango_Boy's Avatar
Durango_Boy
As far as the thermostat housing, you can reuse that one if you like. The chrome ones are prone to leaking, but only because little car was taken during production to keep the mating surface perfectly flat.
To do it yourself, buy a few sheets of 180 grit sand paper or so, tape it flat to a table or work bench with a perfectly smooth surface.
Run the housing, mating surface down, over the sand paper in figure eights...changing direction every so often. Do this for a few minutes...maybe five to ten, and you'll have a great mating surface that won't leak anymore using a standard gasket.
Old Feb 14, 2007 | 05:36 PM
GTR1999's Avatar
GTR1999
DB is right about getting the housing flat. In addition use some "The Right Stuff" RTV on it.
The snubber come with the sleeve. Bolt/nut is extra. That would account for the banging in reverse. Check the ujoints for play as well.
Old Feb 14, 2007 | 05:42 PM
jetdoc's Avatar
jetdoc
Thanks GTR and DB.
The snubber I ordered did not come with the sleeve, thats why I was wondering if it was part of the car or came with THAT particular snubber?
I have not messed with the u joints too much yet, but will.
Old Feb 14, 2007 | 07:24 PM
GTR1999's Avatar
GTR1999
Send it back and get the right one. They should ship you the correct one at no additional cost- shipping.
Old Feb 14, 2007 | 07:36 PM
Kenny Bonnell's Avatar
Kenny Bonnell
That snubber looks like the noise problem, did you get it out Ok? I told you there wasn't much to it. Glad you found the problem (at least I think the problem).
Old Feb 14, 2007 | 08:56 PM
jetdoc's Avatar
jetdoc
The only problem was what I had mentioned above which leads me back to the sleeve question. I've ordered parts in the past and the latest and greatest part was different than the OEM, however it was effective for the car.
Sounds like GTR is saying its the wrong part, I will call Zip tomorrow and double check.
Old Feb 15, 2007 | 12:26 PM
jetdoc's Avatar
jetdoc
Called Zip up and they assured me the part I have is correct and it is indeed the latest and greatest. The old style was rubber and used the metal sleeve for support, the new ones do not, so its good to go.
As soon as I let it off the jacks I will update everyone on if the noise has been corrected, however it will be up for a while...still lots of stuff to do and not a lot of free time.
Old Feb 15, 2007 | 12:32 PM
GTR1999's Avatar
GTR1999
I haven't bought one in about a year but I'm not sure I'd buy what they told you. I'd check with Bairs and couple of other places to see.
Old Feb 15, 2007 | 03:25 PM
jetdoc's Avatar
jetdoc
Good idea man.
Old Feb 15, 2007 | 04:05 PM
jetdoc's Avatar
jetdoc
Went to Biars and they have a #5242
63-79 Rear End Front Mounting Bushing, which looks exactly like what I removed from my car as you can see from the above pic and my first pics. Not sure if "pinion snubber" is another name for, "rear end front mounting bushing"?
The pinion snubber, which zip sent, is not the same. Now Im going to have to dig to the bottom of this.
Looking closer at the drawing supplied by Eddie it sure looks like I have the wrong part, the drawing looks like it has the rubber AND metal insert.
Im thinking the pinion snubber Zip sent is either not to be used in the area I used it in OR it is the latest and greatest and supersedes the one Biars sells?
Anyone know as I sure as hell do not, obvioulsy.
Old Feb 15, 2007 | 04:33 PM
GTR1999's Avatar
GTR1999
The one from Bairs is the correct one and I have used them for this part with no problems. This is what I would use.
If the one you have is poly ship it back - do not use poly. Some of them are/were the wrong size.
Old Feb 15, 2007 | 04:48 PM
jetdoc's Avatar
jetdoc
Yea GTR, the guy at Zip said it is poly and its a better material and doesn't need the metal insert...thanks brother. I am going to send back the old one to Zip and order one from Bairs.
Old Feb 15, 2007 | 05:08 PM
68 NJConv 454's Avatar
68 NJConv 454
Interesting....I got a poly one in my suspension kit from VBP. They claim it is an "upgrade" from the stock style. I don't remember if the one on my car had the metal insert as I was in dismantle mode when I hit the rear suspension. Have to check that out when I get home and see if the metal insert would fit the poly mount. If not, looks like I'll be calling Blair also.
Old Feb 15, 2007 | 05:47 PM
jetdoc's Avatar
jetdoc
NJConv, Zip says that you can either use the rubber one that has a metal insert in it or the new style poly that doesn't require the metal insert. He said the material poly is made from makes it not need the metal, so you are good to go.
Zip said they get about 50/50 on the poly vs rubber orders.
Now this is from Zip, I would like to hear it from some guru's if one is better than the other or it makes no difference? To keep it stock I know the rubber with metal insert would be the way to go.
I am going to hold back on the ordering till I get some more info on the subject. It wasn't a hard install but it is all back together and if everything is the same.....
Old Feb 15, 2007 | 07:20 PM
GTR1999's Avatar
GTR1999
Some of them, and I don't know what brand you have or which brand was a probem, were not the same size. The diff still moved too much and caused a problem.
True, the poly will not rot away like the rubber but the rubber fits and will last a while.
Your call, if it's installed and you don't have a problem good. Otherwise you'll need to get the rubber one.
For me the only poly I'll use on a vette are motor mounts and tranny mounts.
Not all the tranny mounts fit the vette either. A couple of years ago I got a ES tranny mount from Summit and it was .250 off from the stock one. I called the techs at ES and they finally said it would not work on a vette, although the catalog clearly did not mention this. I don't know if they finally changed it but I ended up with a poly mount from Prothane and it fit.
Old Feb 15, 2007 | 07:31 PM
jetdoc's Avatar
jetdoc
Good info GTR, I am going to double check the fit and Im still not sure about keeping the poly or not. Zip has the rubber set up and will gladly take a return.
To Some pics and a few ???.
