Issues with 1000#front springs....
Old Feb 15, 2007 | 04:20 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Originally Posted by turtlevette
They're just giving you opinions based on their frame of reference. Of course 1000# springs are no good for show n' shines.
Remember there are only a hand full of road course guys here. Howard is the only real road racer here. The rest of us are just weekend jagoffs.
I'm actually a poseur right now
Any differences bewteen guldstrands and a circletrack suppliers?
The witches in salem must have took my bushings
Old Feb 15, 2007 | 04:48 PM
69autoXr's Avatar
69autoXr
Circle track springs aren't for Corvettes. Call Guldstrand.
Old Feb 15, 2007 | 06:08 PM
redvetracr's Avatar
redvetracr
Corvette front springs are an odd size....I have never found anyone selling a similar size.
...redvetracr
Old Feb 15, 2007 | 06:21 PM
norvalwilhelm's Avatar
norvalwilhelm
Monty Carlo's have the same OD. I did substitute a monty spring for a corvette spring.
Old Feb 15, 2007 | 06:55 PM
redvetracr's Avatar
redvetracr
where did you find 600-1000# Monte-Carlo springs??
...redvetracr
Old Feb 15, 2007 | 07:02 PM
norvalwilhelm
...redvetracr
i certainly wouldn't begin to ever think about a 600 or 1000 pound spring but I did search for various springs to try in the corvette and I found the monty carlo had the same OD as the vette and would drop right in the vet pocket. I found the monty springs far to stiff for my liking and got rid of them quick.
I was just saying that the monty spring dimensions are right to fit in the corvette. They tend to be quit stiff.
Old Feb 15, 2007 | 07:16 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Im probally better off with guldstrand then
Old Feb 15, 2007 | 07:46 PM
Kid Vette's Avatar
Kid Vette
Originally Posted by zwede
"Because bouncing is what Tiggers do best!".
Old Feb 15, 2007 | 08:22 PM
75 Hot One's Avatar
75 Hot One
Originally Posted by 69autoXr
Obviously this will not be for a road car.
Go to Guldstrand, don't bother with circle track stuff. Although I don't think Daytona springs (860 lb/in) were much taller than 8.5". Curious to know how he came with 24" ride height. They're not going to compress like a lower rate spring would.
Jim Harrison uses Daytona coils, maybe he'll chime in and tell us how tall those are uncompressed and where his ride hieght is at. Danny's car with 1200lb/in springs sat at probably about 26.5" or so with 317/35-17's on the front.
I plan on trying at least Daytona's at some point, my car does not see the street.
Free length of Daytona spring is 10 7/8". Height to top of front wheel well with small block engine (cast iron block & heads) is 26 3/4".
Old Feb 15, 2007 | 08:24 PM
73jst4fun's Avatar
73jst4fun
Dont plan on having a deep oil pan long if you go that low.....
69AutoXR: are you running adjustable heim links on the rear sway bar?, I think they are available from Guldstrand and can you use a sway bar with the stock ends or do you have to switch to different bar with ends that bolt on vertically....
Old Feb 16, 2007 | 12:04 PM
69autoXr's Avatar
69autoXr
No, I'm using factory endlinks on my rear bar, and there was no binding after I corner weighted the car.
Adjustables are available fro Guldstrand but I don't know any details about them.
Old Feb 16, 2007 | 09:19 PM
73jst4fun's Avatar
73jst4fun
Thanks 69autoXR, I emailed them several times but they haven't gotten back to me.....
