Does VBP duel mounted rear spring make a difference??
Old Feb 15, 2007 | 06:43 PM
ImBatman's Avatar
ImBatman
Default Does VBP duel mounted rear spring make a difference??
I got my new VBP catalog yesterday and was reading up on the dual mounted rear spring. Since I am going with 10" rear rims I am loosing my rear sway bar. According to VBP the dual mounted spring in affect replaces the sway bar. Is it worth the money for handling? I have also heard that BB's handle better without a sway bar. Is this true also.
BR
Old Feb 15, 2007 | 07:03 PM
Gordonm's Avatar
Gordonm
Put mine in recently. Just a short test drive so far but no results. I like the idea of having different ratio spring rates. I can drive with a decent rate and when going to the track or autoX just change the rate. It will take about 10 minutes to change the rate.
Old Feb 15, 2007 | 07:18 PM
TPI BOY's Avatar
TPI BOY
BR
I have had mine for about 5 years yes it replaces the rear sway bar just fine
Old Feb 15, 2007 | 07:24 PM
1BAD80's Avatar
1BAD80
I've had mine on for 3 years now and what a difference in ride and handling even for stright line racing.
I have the performance package with off-set trailing arms from VP&B plus their braking package.
Old Feb 15, 2007 | 09:15 PM
JPhil's Avatar
JPhil
Do it, you'll be glad you did. You may have to replace your front sway bar to match the rear dual-mount, but talk to VBP--They will guide you without bullpuckey.
Yes, it's worth it.
Old Feb 16, 2007 | 06:40 AM
Witz's Avatar
Witz
I've had mine for about 12 years.... think it is great. It also takes a load off the diff cover.
To Does VBP duel mounted rear spring make a difference??
