I have a 1975 Vette with 104,000 miles. Time to rebuild the Quadrajet. My question is what do I need for a rebuild kit ? I am not sure if this is quadrajet that came with the car. The only number I found today was on top of the carb and the number is 32747. Any suggestions on where to get the rebuild kit would also help. Thanks.
The numbers on a Q-jet are usually on the pax side if I recall. Just about any parts store can get you a kit. Get a new float too. And get a book about Q-jets. They usually have some good tips.
You can get a rebuild kit from almost any parts store. The box of gaskets usually have a pretty good blown up diagram of the entire carb. It looks complicated, but is pretty easy once it is apart.
Found the numbers, it is a 1975 carb. One more question, there seems to be (2) types of fuel filters. One looks like a normal filter the other looks like it has a plunger for lack of a better term. It is an automatic with factory air. Any thoughts ?
That plunger is really a check valve to prevent the carb from draining back into the tank. Just use a filter that matches your carb. I'd toss that plunger in the trash, but that's just me.
I use the checkvalver filters in every carb I rebuild ("plunger" filters). The checkvalve in the filter keeps the fuel from siphoning out of the float bowl if your fuel pump checkvalve is leaking slightly. This prevents the hard start problems on many Q-Jets. I highly recommend use of the checkvalve filters - don't use the plain open filters. GM used the checkvalve filters for a reason...
