Another steering problem
Old Feb 18, 2007 | 12:32 PM
ohfiver's Avatar
ohfiver
Default Another steering problem
72 big block, auto. with power steering. Jim Shea and others helped me out befor with P/S problem need help again. Replaced pump, adjusted control valve. Now when I let the steering wheel go car turns to the right, no alignment problem befor pump/valve replace & adjustment. Should I try the readjusting control valve. Any suggestions would be appricated.
Old Feb 18, 2007 | 01:07 PM
Jim Shea's Avatar
Jim Shea
Try readjusting the control valve again. Sometimes air left in the system really confuses the control valve adjustment.
Jim
Old Feb 18, 2007 | 01:36 PM
Edzred72's Avatar
Edzred72
Just a few tips that worked well for me:
Mark the adjusting nut on one corner (felt tip marker) and a corresponding mark on the ram to be sure of how many turns. Turn the nut SLOWLY while watching the ram movement.
Good Luck....
Eddie
Old Feb 18, 2007 | 10:45 PM
StickShiftCorvette's Avatar
StickShiftCorvette
Also confirm that the power cylinder rod should move easily when the valve is properly adjusted (with the engine running).
Old Feb 21, 2007 | 09:35 AM
ohfiver's Avatar
ohfiver
Thanks you all. Will givre it a try.
To Another steering problem
