'75 Fast Idle - Choke Problem
Old Feb 18, 2007 | 01:54 PM
PETKAH's Avatar
PETKAH
Default '75 Fast Idle - Choke Problem
My '75 sometimes take 5-10 minutes to come down from fast idle.
After a ride the fast idle linkage is "frozen" - that is it will not
move by hand but, when the engine cools it works fine. There
is a 1 x 2 inch black box that feeds the electric choke with two
wires - that black box gets two wires from the harness.
What is that black box and could that be my problem.
Hope you can help
PS; That little black box is about 3 inches from the carb
and is mounted on a manifold bolt.
Old Feb 18, 2007 | 01:59 PM
thrilher's Avatar
thrilher
spring arrangement for electric choke?
Old Feb 18, 2007 | 02:21 PM
PETKAH's Avatar
PETKAH
The bimetal spring should be behind the choke plastic housing on the
carb. Perhaps more ideas after the "500"??
To '75 Fast Idle - Choke Problem
