Need Help - Tilt Steering pin removal???
Old Feb 19, 2007 | 04:29 PM
82MDVette's Avatar
82MDVette
Default Need Help - Tilt Steering pin removal???
I am in the process of rebuilding the tilt/telescoping steering in my 82 Vette. I have gotten to this point but am stuck! I can not figure away to remove the pin at the top of the tilt mechanism. Both of the pivot pins have been removed, but I can not break it down any further. When I wiggle the tilt mechanism, it is hung up by this silver pin that runs from side to side. There is a flush, flat side and a tapered end that protrudes out past the housing by approx. 1/8 of an inch. I have tried driving it out in either direction with no success.
Please help???????
Old Feb 19, 2007 | 05:10 PM
kortensi's Avatar
kortensi
If I remember correctly, once the pins are out, I had to screw the tilt lever back in and release the "tilt". Then the shaft just came out. I never had to remove that pin.
Old Feb 19, 2007 | 05:37 PM
TimAT's Avatar
TimAT
Check Jim Shea's tech stuff, but I'm with kortensi on this one. I don't think that pin has to come out.
Old Feb 19, 2007 | 06:11 PM
Jim Shea's Avatar
Jim Shea
From 1969-82 T&T Steering Column Disassembly & Repair Paper #3
"Remove housing by pulling upward on the tilt lever and pull the housing upward until it stops. Move the housing to the right or left to disengage the rack #37 from the ignition switch rod #38. Pull the housing up off the steering shaft assy."
Jim
Old Feb 19, 2007 | 08:25 PM
82MDVette's Avatar
82MDVette
Jim
Jim and Kort Thanks!
Jim,
I read all of your papers for the T/T column and I could not get the assembly apart after following the directions. I will try again and let you Guys know what happens.
Thanks.
Old Feb 19, 2007 | 08:38 PM
82MDVette's Avatar
82MDVette
DIDN'T WORK. I guess maybe I need some clarification.
Jim,
I had the column with shaft down at the ground and the tilt hub towards the ceiling. When you say "by pulling upward on the tilt lever", is that towards the ceiling or in towards the housing? I tried both directions.
I am then to "pull the housing upward until it stops". Is that towards the ceiling? My housing really does not move at all, maybe just a fraction.
I can not get the housing to disengage from anything.
Man, I can bench 400lbs as a bodybuilder, but I must be doing something wrong here. I can't get this to budge.
Old Feb 19, 2007 | 09:28 PM
TimAT's Avatar
TimAT
Pull the tilt lever in the normal direction, as if you were adjusting it, hold the lever in that position and pull on the whole upper bowl. The upper bowl should come off. What you're doing is releasing the tilt latch(?) from the lower part of the column. It dosen't take a lot of effort, but you may have to wiggle it to get all the parts seperated..
Old Feb 19, 2007 | 09:39 PM
kortensi's Avatar
kortensi
You can also try putting the pivot pins back in (not all the way) and then try releasing the tilt.
Just an idea.
KO
Old Feb 19, 2007 | 09:41 PM
kortensi's Avatar
kortensi
I think upward is actually towards you as if you were sitting in front of it while driving.
Old Feb 20, 2007 | 10:01 PM
kortensi's Avatar
kortensi
any luck?
Old Feb 20, 2007 | 10:25 PM
VETTEVIC's Avatar
VETTEVIC
Remove the spring!
You take a socket extension (I beleive its 1/4in) and put in the square hole where the spring is on the bottom of the column, have a friend hold the column if not in car and push on the plate with the square hole and turn to release. Then SLOWLY let it back out of the hole until the tension is off the spring then pull the spring out. Now you will have no problem getting the pins out if the are not grooved or pitted. Also, if you need to you could use a dent piller and a small machine screw that fits the threads in the pins and pill them out that way. I dont remember the thread size in the pins.
Old Feb 21, 2007 | 03:02 PM
82MDVette's Avatar
82MDVette
any luck?
Nope, I'm lost! Put the column in the vise and tried it, but no go.
Old Feb 21, 2007 | 03:23 PM
kortensi's Avatar
kortensi
Have you already removed the spring retainer?
Old Feb 21, 2007 | 05:18 PM
82MDVette's Avatar
82MDVette
Kort,
Yes. This is where the column is at now.
Old Feb 21, 2007 | 10:11 PM
Jim Shea's Avatar
Jim Shea
I am at a loss right now with this one. Interesting, we have another thread where we can't get the turn signal switch cover off. This one has the cover off but now we can't get the bearing housing off.
I will call my skilled trades retiree friend tomorrow. He used to assemble prototype Saginaw columns. We are asking him to remember back 30+ years but he is pretty good.
Jim
Old Feb 21, 2007 | 10:22 PM
VETTEVIC's Avatar
VETTEVIC
Thats the pin that catches the teeth on the tilt position locking arms. Pull your tilt lever to disengage the teeth from the pin and the bearing housing should come off with a little tilting. Its been a few months since I did mine but I do remember running into the same problem with the teeth catching on the pin. As long as your spring is removed it should be easy to pull the lever and wiggle the bearing housing off.
Old Feb 22, 2007 | 02:01 PM
Jim Shea's Avatar
Jim Shea
You really have us stumped! I talked at length with my retired skilled trades man. We really didn't come up with much.
One thought. When you were first trying to drive out the pin that holds the lock shoes. Did you already have the two pivot pins pulled out of the support? I wonder if you might have damaged something. Since the bearing housing was not supported.
I would suggest that you reinstall the two pivot pins. Now screw in the tilt lever. Pull the tilt lever toward the steering wheel (unlocking the shoes). Does the bearing housing easily pivot to each of the positions where the lock shoes engage?
If it pivots up and down easily. Try removing the two pivot pins. Pull back on the tilt lever and try wiggling the bearing housing to get it to release from the steering shaft and the support.
Jim
Old Feb 22, 2007 | 02:03 PM
kortensi's Avatar
kortensi
To Need Help - Tilt Steering pin removal???
