wiring Question
Old Feb 22, 2007 | 01:59 AM
lorijones's Avatar
lorijones
Default wiring Question
I have the color wiring diagram from Doc Rebuild's and was able to find everything regarding the wiper system exceptto the Wiper door switch connect which is a brown wire with white stripe. Any ideas what this is and where it's located? Please don't tell me its the swithc that my wipers is suppose to hit when completely down!!! I don't have one.
Old Feb 22, 2007 | 09:36 AM
wombvette's Avatar
wombvette
I guess the switch that you want is the one behind the speedometer. A single wire with a vacum switch.
Old Feb 22, 2007 | 12:49 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Are you looking at the right wiring diagram?
There are two Dr Rebuild diagrams for your car - do you have both?
The wiper override switch wire is on the dash harness diagram
(top center) as that wire is not part of the ignition harness which has the connectors for the wiper motor itself.
Old Feb 22, 2007 | 02:37 PM
lorijones's Avatar
lorijones
Yes, I have both doc rebuild's diagrams and I actuall wrote them to find out that there was an actual wiper door override switch that they no longer make and no one is making a repo. Looks like a wiper motor override switch with only one elec. prong.
To wiring Question
