Push Rod Length
Old Oct 7, 2001 | 09:01 PM
rayray's Avatar
rayray
Default Push Rod Length
I'm trying to check my push rod length, using a tool from Jegs, page# 105-H. It's blue and looks alittle like a rocker. Does it go down on the stud just like the book shows or does the flat top go down to hit push rod and valve stem. I'm building an 383cid small block with trick-flow heads and crane roller rockers. I was told to use 7.900" in stead of standard lenght rods. Thanks Ray.
