80 windshieldwiper switch
Old Feb 20, 2007 | 07:01 AM
dixie vette's Avatar
dixie vette
Navigator
Default 80 windshieldwiper switch
Has anyone ever replaced windshieldwiper switch? And if so how difficult was it? Thanks in advance for any help!
Old Feb 20, 2007 | 04:18 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
I'm pretty sure you have to remove the dash to do so. I forgot the upper wire harness on mine while putting the dash back together. That was enough of a pain that I would never try to change the switch with the dash in place.
Old Feb 21, 2007 | 09:10 AM
Schwee's Avatar
Schwee
I'd also like to know for sure. I just bought the wiper switch at last week's Corvette show in Houston but I'm not really interested in pulling the entire dash on my '81 daily driver.
Old Feb 21, 2007 | 09:22 AM
jdp6000's Avatar
jdp6000
Its easy. Remove the lower dash pad....the one that runs along the bottom of the steering wheel. Reach up and undo the one and only screw/bolt that holds it in place. Take the **** off. It should drop down. If its the delay you are having problems with its not the switch but the module in the rear passengerside compartment.
Jim
Old Feb 21, 2007 | 09:27 AM
Bangkok Dean's Avatar
Bangkok Dean
Originally Posted by jdp6000
If its the delay you are having problems with its not the switch but the module in the rear passenger side compartment.
Jim
I hope you don't need the Module as they are difficult to find.
Old Feb 21, 2007 | 09:51 AM
dalewilson99's Avatar
dalewilson99
It can be repaired, working on one right now.
Old Feb 21, 2007 | 11:59 AM
thrilher's Avatar
thrilher
while restoring my '79 i changed the wiper switch and it worked. after getting it together to drive the wipers work but the delay has stopped. i will have to remove my dash to remove it. i want to know more about the passenger side module mentioned in this post...could that be my issue? exactly where is it located and does it run on vacuum or?? my new switch was made in MEXICO and i thought that was the problem.
Old Feb 21, 2007 | 02:56 PM
jdp6000's Avatar
jdp6000
I'm guessing that the 79 is the same as the 82...we have the same interior. The module is located under the compartment behind the passenger seat. You need to remove the plastic tray to see it. It should be bolted to the wall.
If your switch operates your wipers the switch is fine. Check for that module.
Jim
Old Feb 21, 2007 | 11:38 PM
thrilher's Avatar
thrilher
i'll have a look, thanks jim
To 80 windshieldwiper switch
