How hard is it to remove/replace A-arms?
Old Feb 21, 2007 | 08:42 PM
MakoShark72's Avatar
MakoShark72
Default How hard is it to remove/replace A-arms?
I'm betting its a PITA, but need to replace bushings, etc..Special tools? Need some advice..
Thanks in advance!!!
Old Feb 21, 2007 | 08:48 PM
72LS1Vette's Avatar
72LS1Vette
I believe Lars has a paper detailing A-arm removal. It can be done without a spring compressor if the body is on the car. It can also be done without a compressor on a bare frame with a bit more drama. If you want to replace the bushing shells you will need to press them in but other than that I can't think of any special tools that you will need.
Rick B.
Old Feb 21, 2007 | 09:05 PM
Merlinhaggard's Avatar
Merlinhaggard
Im in the process of doing mine right now. I have A 68 but it should be the same..
Pull the Wheel, caliper, hub assy, shock mt upper
Disconnect the sway bar, steering
pop the upper ball joint loose (get a ball joint fork)
then the bottom ball joint
remove the spindle
then the frame mts where the upper a-arm connects
Pull the upper a-arm off.
Remove the lower a arm bolts the lower a-arm, spring and shock will fall
remove shock mt lower pull the shock out
Thats it
IOt took me about 1 1/2 hr to pull 1 side apart. I had to heat some bolts up to get them out..
Old Feb 21, 2007 | 09:08 PM
Merlinhaggard
remove the spindle
Thats it
Oh yea, I put the a arms on my vise and used a small drill bit and drilled holes around the bushing to get the rubber out then pulled the shaft out of the upper. The shaft wont come out of the lower. Its longer. Then you beat the bushing sleve off of the shaft..
Old Feb 21, 2007 | 10:21 PM
seventysixvette's Avatar
seventysixvette
I do mine the same way. I don't beat the inner metal sleeve off the shaft though, I use a little WD-40, drive a screwdriver into the split in the sleeve. There's always a ton of rust under those things. Wipe them off, and chuck 'em into the bead blaster. I don't use a press to put them together, I just drive them in.
John
Old Feb 21, 2007 | 10:22 PM
gleninsandiego's Avatar
gleninsandiego
If you are in a hurry you could do this but I don't recommend it
Old Feb 21, 2007 | 10:46 PM
bene's Avatar
bene
An easy way to get the bushings out is to use a one inch hole saw. It cuts through the rubber easily and then you can remove the sleeve. I just did mine. It takes about 15 minutes per bushing. Someone before posted how to do it with the hole saw. It works and it is easy.
Old Feb 21, 2007 | 10:52 PM
thrilher's Avatar
thrilher
you can get a rental spring compressor free with purchase, your probably gonna need lower ball joints too. tear it down to ball joint and check lowers, theres a 2 day limit on spring compressor usage. getting ball joints out can be a task if u don't have the proper tools, theres 3 diff types ball joint tools i've seen that work,some better than others, i used the split fork hammer type and my hammer got a workout, plan your work, work your plan and you can do it all in a day and get the rental unit back with plenty time. just order your bushings and have them on hand before u start.
Old Feb 21, 2007 | 11:12 PM
MakoShark72
OK, you guys have talked me into it. Will order the parts tomorrow! Beats a grand$ quote from the local shop!! Pictures when I get them!!!
Old Feb 21, 2007 | 11:29 PM
my2nd78's Avatar
my2nd78
Be careful with the spring. I just did mine as well. Pull the shock then run a piece of all thread down thru the spring. Put a big washer or plate on either end of the all thread followed by a nut. tighten the nuts at the top and bottom to compress the spring. Once you've broken the ball joints loose slowly lossen the nuts to let tension off of the spring. This is a safe way to do it. It may take some time to tighten and untighten the screws on the all thread, but its worth it.
Old Feb 21, 2007 | 11:55 PM
TimAT's Avatar
TimAT
There's enough energy in that spring to blow your head off. Well, not really, but you'll need some stitches.
Old Feb 22, 2007 | 07:59 AM
Wuttin's Avatar
Wuttin
On my 79 I had to press out the upper control arm mounting studs to get the arms free. As per the Lars paper (look on corvette faq, paper is generic for C2 and C3 front suspension rebuild) I used a 4" C-Clamp and an oversized socket to press the bolts out. Otherwise I would have had to take out the rad and the shroud. Not a bad job overall.
I sent all the control arms off to VanSteel for a full refurb...beautiful job and easy to rationalize the cost since I wasn't paying labor for the "easy" work. Popped them filthy suckers in a box and they came back all shiny and new. ~$400 for a poly package with the CF member discount (less for rubber), includes rivetted balljoints and bumpers. Worth considering...
http://wiki.corvettefaq.com/index.php?title=Suspension
Rebuild Front End in a C2
Old Feb 22, 2007 | 08:21 AM
Merlinhaggard
If you jack the wheel off the ground there sholdnt be any spring pressure. Of course if you dont your car will probably fall as soon as you pull the tire off. I've never heard of a spring having pressure??.
Old Feb 22, 2007 | 10:23 AM
MakoShark72
Will definitely consider, sounds like a heck of a deal!
Old Feb 22, 2007 | 11:14 AM
lars's Avatar
lars
My paper outlines the entire process with all tools needed. It's very easy and quick to do. You can e-mail me for a copy. You don't need a press or a spring compressor, but it does help to have air tools.
V8FastCars@msn.com
Lars
Old Feb 22, 2007 | 11:25 AM
72LS1Vette's Avatar
72LS1Vette
Not correct. The springs are under tension even with the wheel off the ground. Stock springs are probably compressed 3-4" , 550 lb springs are compressed much less. Still, you can't take the nuts off the ball joints without restraining the spring.
Rick B.
Old Feb 22, 2007 | 11:40 AM
lars's Avatar
lars
To How hard is it to remove/replace A-arms?
Old Feb 22, 2007 | 06:09 PM
Merlinhaggard
Rick B.
When I poped the upper joint it just dropped kind of normal. Am I gonna have to do anything to put it back in?. Also do you guys think I should cut them while I have em out if I want to lower the front end and how much??.
Old Feb 22, 2007 | 07:58 PM
SILVERSIXX's Avatar
SILVERSIXX
V8FastCars@msn.com
Lars
Lars Rules All B******
Old Feb 23, 2007 | 07:56 PM
72LS1Vette's Avatar
72LS1Vette
If your A-arm dropped without a bang you might already have 550 springs or cut stock springs. I'll post a pic this weekend of a stock 72 spring and a VB&P 550 spring side-by-side and you can figure out what you have.
Rick B.
