drilling 1.6 pushrod slots
Old Oct 8, 2001 | 09:24 AM
ZD75blue's Avatar
ZD75blue
Default drilling 1.6 pushrod slots
http://www.jegs.com/cgi-bin/ncommerc...76&lastcat=537
Thought you guys would like this
"This tool was designed to simplify the modification needed when using 1.6 rocker arms on SB-Chevy heads. It allows you to use a hand drill with a 5/16'' bit to elongate the pushrod slot exactly in line with the existing slot, thus eliminating the need for guide plates."
ZD
:cool:
Old Oct 8, 2001 | 10:59 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default good post
good post because a lot of people do not know that you must make the push rod slots longer in the heads when switching to 1.6 rockers because the push rod seat in the rocker is closer to the pivot point.
Old Oct 8, 2001 | 11:01 AM
KenSny's Avatar
KenSny
Default Re: good post (clem zahrobsky)
You should also open them up if you add guideplates.
Old Oct 8, 2001 | 11:11 AM
clem zahrobsky
Cruise-In I Veteran
Default Re: good post (KenSny)
if you add guide plates you should ream the hole to 7/16" dia. as you also need side to side clearance.
Old Oct 8, 2001 | 06:16 PM
LT1driver's Avatar
LT1driver
Do small blocks with guideplates already have the holes enlarged?
Old Oct 8, 2001 | 06:30 PM
clem zahrobsky
Cruise-In I Veteran
Default Re: good post (LT1driver)
heads that came stock with guide plates have no problem. :chevy
Old Oct 8, 2001 | 07:58 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Why does the idea of grinding / drilling the cylinder head WHILE IT IS ON THE MOTOR not sound like a smart idea???? :confused: :confused:
Where are the metal shavings going to go ??
[Modified by BSeery, 3:59 PM 10/8/2001]
Old Oct 8, 2001 | 09:32 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Default Re: good post (BSeery)
If you're not careful the shavings could get to the valley drain holes, the intake ports, and even onto the valve stems. Cast iron drill shavings will be mostly of a dust type. FYI - I did open mine up to 9/16 with a drill, with the heads mounted and the intake manifold off.
I placed and wedged paper shop towels around the surrounding areas and over the valley. I drilled the holes over size one at a time, each time using the shop vac to suction up the shavings and replacing the shop towels as I went along.
Grinding the slots is a lot messyer(sp?). The grinding dust can travel several feet easily. The best bet there is totally cover everything and tape the edges down. Vacumn off the dust and wet wipe when done before removing the coverup material.
Old Oct 8, 2001 | 09:33 PM
KenSny's Avatar
KenSny
Why, they are going to travel all around the engine - a scrubbing and-a grinding, cleaning up all that nasty gunk for you....
To drilling 1.6 pushrod slots
