Equation to determine final ratio?
Old Feb 23, 2007 | 11:16 AM
clive's Avatar
clive
Default Equation to determine final ratio?
Is there a math equation to determine the final ratio using transmission ratio, tire size and rear differntial? I am interested in seeing how they relate the trans ratio to the diff. I know there are calculators to determine that stuff but I would like to crunch the numbers myself.
Thanks in advance.
Dave
Old Feb 23, 2007 | 11:26 AM
theoUK's Avatar
theoUK
Yeah, you just multiply!
If your diff ratio/final drive is 3.55:1, and your gearbox ratio is, say 1.5:1 (top gear is normally 1:1, but I'm just using a number other than 1 to demonstrate), then your overall gear is 3.55 x 1.5 = 5.325:1
So when your engine's spinning at 3000rpm, the back wheels will be spinning 5.325 times SLOWER, ie 563rpm.
Or, say you have an overdrive box where top is 0.65:1, then with the same rear end the overall ratio is 0.65x 3.55 = 2.31:1 In this case at 3000 fwrpm, you have 1300rwrpm.
The circumference of a tyre is pi x Diameter, then you have all the information you need to work out road speed.
Old Feb 23, 2007 | 11:32 AM
wfo76's Avatar
wfo76
RPM x Tire Diameter
------------------------------ = MPH
Axle Ratio x Trans Ratio x 336
Old Feb 23, 2007 | 11:33 AM
clive's Avatar
clive
Easy enough!
I was expecting a little more complicated.
Thank You!
To Equation to determine final ratio?
