It's tech, I swear.
Old Feb 26, 2007 | 10:19 AM
  #41
genuine1980's Avatar
genuine1980
Originally Posted by Durango_boy
Make my own additive for engine oil.
I don't think adding zinc to oil will supplement.... this kinda sounds like those ppl who put a block of lead in their gas tank thinking it would turn unleaded gas into leaded gas.
But I could be wrong...
Old Feb 26, 2007 | 10:25 AM
  #42
Durango_Boy's Avatar
Durango_Boy
I didn't mean just add zinc...I meant make my own additive int he event that the gov takes it out completely. You know...play mad chemist and mix one up ourselves.
Old Feb 26, 2007 | 11:36 AM
  #43
Big2Bird's Avatar
Big2Bird
So I should have someone cut some cooling fin blocks out of aluminum, Gorilla glue them to the sides and back of the oil pan, paint them with a special paint, and that alone will get 13 degrees? Cool.
Isn't Gorilla glue rubber based, therefore an insulator?
Old Feb 26, 2007 | 11:45 AM
  #44
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Not if you make your own Gorilla glue.
Dep
Old Feb 26, 2007 | 11:51 AM
  #45
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Originally Posted by Yellow73SB
What do you say to people when they ask you why you put pills in your engine?
Its for better gas mileage.
Old Feb 26, 2007 | 11:53 AM
  #46
DJ Dep's Avatar
DJ Dep
My engine sounded "sick", so I'm treating it.
Dep
Old Feb 26, 2007 | 11:55 AM
  #47
Durango_Boy
Maybe, that was sarcasm. I tested it once like I saw in the Home Depot stores. You know, glues a screen door 'D' handle to a cinder block. It wouldn't hold no matter how much or little I used, how clean the block was, or the temp or time the glue was cured at. That stuff MAY work on some things but I think it's bull.
If I were really gonna attach fins I would have the welded on.
Old Feb 26, 2007 | 12:02 PM
  #48
DJ Dep's Avatar
DJ Dep
I've had mixed results with GG. Worked good on 3 of 4 chair legs I glued. Did work good to glue the electric eye for my headlight sensor on my truck. And that was plastic-to-plastic.
Dep
Old Feb 26, 2007 | 12:05 PM
  #49
Big2Bird's Avatar
Big2Bird
A) Sarchasm
B) You meant still something else.
C) You are SERIOUS
Old Feb 26, 2007 | 12:11 PM
  #50
Durango_Boy
A) Sarchasm
C) You are SERIOUS
C - I said make my own additive. That followed finding zinc to buy. If I knew the complete ingredient list that would accomplish making that additive...and if I could get the ingredients I would seriously consider making that additive.
Obviously all that revolves on the premise that oils will no longer have zinc and other additives that I would prefer ti keep in my engine oil.
Now, as mentioned above I think it would be much easier to just buy GMs additive.
Old Feb 26, 2007 | 01:04 PM
  #51
DJ Dep's Avatar
DJ Dep
DB: Looking at oil coolers in the Summit and Jegs catalog, they all look like a trans cooler and have fins. I wonder how efficient the one in your picture would really be? And maybe it's a solution looking for a problem? Do you live in an area that gets extremely hot (I do). Also depends on the type of driving you plan on doing.
Dep
Old Feb 26, 2007 | 01:09 PM
  #52
Durango_Boy
Dep
I do live in an area that gets above 100 in the summer which as we all know radiating of a road surface can get much higher to the car.
I have had problems and see lots of problems with hot fluids and a hot engine.
When I install the new motor and trans I want to cover all the bases right up front. I want the power steering system to have a cooler, and the same goes for the engine oil and transmission oil.
I did not buy the item from post #1, as it's just tied into the coolant system, and I don't want something else adding heat to it. I decided on using the sandwich adapter I have, installing an oil cooler, just like a trans cool, and mounting them in the back where the spare used to be. I will likely mount both the trans and engine oil coolers back there.
I'm still deciding on if I want a fan switched by a thermostat.
Old Feb 26, 2007 | 01:12 PM
  #53
Big2Bird's Avatar
Big2Bird
You have decided the engine oil temp is more important than having a spare?
Old Feb 26, 2007 | 01:14 PM
  #54
Durango_Boy
Not really related, but yep. I ditched the spare a LONG time ago. It has nothing to do with the coolers...they are just gonna take up it's space.
I have road side assistance, a cell phone
What I don't have is a jack that'll fit under the car if a tire is flat.
Old Feb 26, 2007 | 01:16 PM
  #55
DJ Dep's Avatar
DJ Dep
I dunno about mounting the oil/trans cooler in the back. For sure you will need a fan if you do. Those fin jobs work on large amounts of air flowing over them. Most I've seen were mounted in front of the radiator. Plus you are gonna have some LONG lines going back there.
Sounds like a very complex setup to get the job done. Remember also that oil has to be at a certain temperature to be effective/efficient. That's why you install the thermostat. If you drive in cold weather you DON'T want that oil to be cooled too much. It will reduce the flow and could do more harm than good.
Dep
Old Feb 26, 2007 | 01:19 PM
  #56
DJ Dep's Avatar
DJ Dep
Ditto for me. But I don't drive on the street
I do have a floor jack that can get under a Vette with a flat, though.
Dep
Old Feb 26, 2007 | 01:20 PM
  #57
Durango_Boy
Dep
I agree with all that. Yes, the lines will be ling but that may play to my advantage. I don't want them up front as I want all air going into the radiator to be outside air cool, not passing through another hot radiator before it's supposed to go though another already hot radiator that's trying to keep the engine cool.
So long as they are mounted correctly, they won't be overly effective until the fan kicks in. I could use one fan for both I think if I mount them right.
It does get cold here but I don't drive it much at all in the winter, as we get frozen precip which adds up to poor traction for high HP rear wheel drive cars. I have a 4x4 for the fun seasons.
To It's tech, I swear.
Old Feb 26, 2007 | 02:55 PM
  #58
BerniesVette's Avatar
BerniesVette
Just a thought here. I mounted an engine oil cooler behind my electric fans. The air that is pulled thru the A/C condensor and radiator is blown across a B & M stack type cooler. It is effective and the lines are much shorter than running them to the rear of the car. I had thought about plumbing a fan and cooler where my my spare used to be but I bought a Derale tranny pan and will check it this summer to see how much it helps. If I need more cooling for the tranny I can either mount a cooler in front of the A/C condensor or install it in the rear. Several have done this and works fine for the transmission. On my 79, I replaced the auto with a T5 and got rid of that heat source all
together. I don't like the idea of having to pump engine oil all the way to the back of the car and forward again. Those that have done it have used another pump in addition to the engine pump. Engine oil temps follow engine temps but they need to be hotter to vaporize the condensation that occurs in the block. Again, these are my personal opinions based on my experience with the type driving I do.
Bernie
Old Feb 26, 2007 | 03:16 PM
  #59
Durango_Boy
Thanks so much for the tips Bernie. I'm still working on the overall plan and it'll probably change ten times before I get to it.
Old Feb 26, 2007 | 03:49 PM
  #60
Little Mouse's Avatar
Little Mouse
You don't need an engine oil cooler your not going to road race
the car. Break it in on dino oil switch over to synthetic. The cam
you put in your 400 is a 5000 rpm engine your not going to work
the engine hard enough to need an engine oil cooler. All your going
to do is put a bunch of external pluming on your car for no reason.
