timing marks 454 ?
Old Feb 24, 2007 | 02:19 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default timing marks 454 ?
Please take a look at the pic below. I realize the marks are not perfect at 12'oclock, but "close enough" considering the slack in that old timing chain.
Confirm that this "is good". My rotor button is pointing at the #1 position on the distributor. There is no tension on either rocker arm for cyl #1, which says both valves are closed.
IF this is truely TDC - compression stroke #1 - not exhaust.....I was expecting timing gear marks to be at 6'oclock (cam) and 12'oclock (crank). Not both marks at 12'oclock. I just want to be sure I "know what I'm doing".... ....before I get any deeper in replacing this camshaft.
I need a big blocks for dummies book!
Thanks for any input.
Old Feb 24, 2007 | 05:37 PM
Ironcross's Avatar
Ironcross
your on one,
Old Feb 24, 2007 | 06:40 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Originally Posted by Ironcross
your on one,
shouldn't the marks line up at 6 & 12?
Old Feb 24, 2007 | 06:52 PM
Ironcross's Avatar
Ironcross
They can except your firing on 6 then, not 1.
Old Feb 24, 2007 | 07:03 PM
lars's Avatar
lars
That's a common misunderstanding. On a Chevy, when the #1 cylinder is at TDC on the compression stroke, both timing mark dots point straight up (12:00 o-clock). When the crank is at 12:00 and the cam is at 6:00, #1 is at TDC on the exhaust stroke and #6 cylinder is in the firing position.
He's got both marks straight up (or pretty close), so that means the rotor should be pointing to the #1 plug wire location.
Old Feb 24, 2007 | 10:40 PM
fotyfobravo
Thanks all........that's what was messing with my head. Makes sense now. "The math" all fits now.
BTW Lars.....by the time we flew into Denver last week....went to "the springs".....then Breck.....I never had a chance to buy you that brewski I owe you. Next trip out there I will plan things better.
To timing marks 454 ?
