I can't figure this out. New motors in both doors installed. Tested both motors with current and ground from battery before and after install. O.K. Checked for power from switches to both wiring harnesses before install. Both sides have power up and down. Installed motors. Motors will work for only a sec. (or not at all) and quit and only every now and then. I am quite sure that ground is O.K. because if power is applied directly from battery, motors work fine (up and down) using only a hot lead from battery and ground supplied by door sheet metal. I checked the voltage of wiring harnass at motors and believe it is full voltage. Could it be the switches? Both? Could it be the relay? I am really confused.
There is a relay. I think that would be the more likely culprit with both windows acting up.
From what I have read before relay is usually under shifter console I think. I was thinking relay but can I have power to both harnesses when switches are operated (up and down) and still be bad relay. How?
I'm pretty sure the relay provides power to the switches IF the ignition switch is in the accessory or run position. The relay is in the front portion of the console and can be accessed by removing the shifter plate. The relay was my first thought when I read this. There is also a circuit breaker which is mounted on the firewall in the engine compartment (At least for the early C3's --I'm not sure for later ones).
I did all tests where I expected power with key to on but not running. The harness shows power when switches are activated. If it was circuit breaker, or relay for that matter, could I have power and not run motors? Can I have low voltage? Intermittent voltage?
Run power while it glitches does it stay hot @the motor?
Your power window motors pull a LOT of amps. It could be you have a weak connection where you can measure voltage with your volt meter (because it pulls very little amps) but when you apply a load such as your power window motor, the circuit opens because of a weak or intermittent connection. The best thing to do is to systematically jumper a hot wire directly to the motors (you've done that), then to each of the switches to see if they operate the windows properly, then to the relay, and on, until you go all the way back to the horn relay which is the main junction where the power window circuit gets its power. There really is not that many components in the power window circuit so the likely culprits as far as I can tell are, the window switches, the relay, or the circuit breaker. Also check to see that all of the connections at any connectors are free of corrosion and are making good contact.
"those old ones dont have a relay." Mine has a relay and it's a '68.
true AKA the power probe can also do so much (power& ground check )
Thank you. I am no electrical genius but I think you are saying that I can read correct voltage but not have enough power. It may be there but too weak? All things considered that at least seems possible. I will check all you suggest. How is the horn relay involved? The rest seems obvious.
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
grab the wires where they go through the door opening when the door is open.......and wiggle them while depressing the power switch......sometimes the wires break inside the plastic sheating and work intermittenly..........if everything checks out ok but the window still doesnt work...look here next.....so when the window doesn't work try wiggling the wires in the open door space while depressing the switch.......if the window activates you have a broken wire
Already tried it. Read about it in previous thread. Power is there (and not intermittent) and ground is good. I will double check it though. Can't hurt.
Thanks.
