Parking brake console removal help.
Old Feb 24, 2007 | 08:57 PM
#77's Avatar
#77
Default Parking brake console removal help.
I have removed the 4 visible screws on sides of the console but it is still secured at the rear. It seems like the only way to free the rear of console is to remove bolt who's head is accessible only from center rear storage compartment. I can't even get a wrench in there. Am I missing something?
Old Feb 24, 2007 | 09:09 PM
kansas123's Avatar
kansas123
I had to reach that bolt by removing the tub under the hinged door behind the passenger seat where the jack storage is. It wasn't too bad; I have not put it back yet, I suspect that will be more difficult.
Old Feb 24, 2007 | 09:14 PM
aussiejohn's Avatar
aussiejohn
Default That's it!
77,
Yes, that's what you'll have to do as they were designed like that. One of the best things you can buy for your 'Vette is an A.I.M. and a good workshop manual. Then, when you have a problem, you can go straight there and obtain an immediate answer to your question.
I'm NOT saying that the Forum is the last reort - nothing like it - but try the W.M. and the A.I.M. first for the easy problems. Come here for the hard ones!!! LOL
Regards from Down Under
aussiejohn
Old Feb 24, 2007 | 09:38 PM
#77's Avatar
#77
I did the same. I can feel the bolt head but how did you remove it? It seems to be a 7/16", but I can't seem to get a socket or wrench on it. What did you use?
Old Feb 24, 2007 | 09:47 PM
#77's Avatar
#77
Originally Posted by aussiejohn
77,
aussiejohn
Will do. Do you have a recommended source for good quality A.I.M. and workshop manual? Also I read books and search previous threads for answers to questions before posting them here but there is no substitute for past experience and the ability to ask a follow up question. Simplicity or complexity of question aside, is that not the purpose of the tech section of the forum?
Old Feb 24, 2007 | 10:40 PM
7T1vette's Avatar
7T1vette
Use a box end or open end 7/16" wrench to get the rear retaining bolt loose.
Old Feb 24, 2007 | 11:10 PM
#77's Avatar
#77
Will do. It is very difficult to reach that way. Tried it repeatedly and got aggrevated. Hoped that there was an easier way. Will try again in AM.
Thanks.
Old Feb 24, 2007 | 11:42 PM
7T1vette's Avatar
7T1vette
It is a "pain" to remove that way. But getting better access to that bolt takes even more work! Just be patient and it will come out.
Old Feb 25, 2007 | 12:52 AM
tallguy222's Avatar
tallguy222
I put a new parking brake consol in recently and that bolt beat me !
I simply couldn't twist my body to get it without getting frustrated.
I removed the entire rear consol and then there was lots of lovely room to work with
I'm glad I did because getting it back in was hard even with the room.
The way you do it will depend on your patience/body size/frustration level
Old Feb 25, 2007 | 01:07 AM
Gearhead74's Avatar
Gearhead74
Default A little easier next time
If you have any reason to think you'll have to remove the console again in the future, replace the troublesome bolt with an allen head cap screw. Getting the cap screw into the hole is pretty easy when it's on the end of a six inch allen wrench.
Old Feb 25, 2007 | 08:56 AM
#77's Avatar
#77
Thanks to everyone for all the help. I'll try it again.
Old Feb 25, 2007 | 09:06 AM
norvalwilhelm's Avatar
norvalwilhelm
I must have gotten lucky. I bought my 75 second hand but that bolt for me was just a stud. I removed the side screws and then just pulled the cover forward and it slit off the stud. Mine was NOT attached by this bolt. The bolt was mearly a stud over which the console slid.
Old Feb 25, 2007 | 12:29 PM
7T1vette's Avatar
7T1vette
That is a "trick" idea. The rear console isn't going to move forward on its own, so it only needs to be restrained from moving sideways or up/down. The stud idea would do that well and doesn't need to be removed. Wow!
Old Feb 25, 2007 | 08:40 PM
#77's Avatar
#77
The stud idea is a good one. My first thought during removal was that it would be held by a slip on bracket that would keep it from moving up or down and that the other screws would keep it from moving forward. (Too bad we didn't work at GM's design department in the '70's. ). I may change it to a stud for re-assembly.
My solution was pretty simple. I tried the wrech again and decided I would rather break somethig or cut an access hole or etc. It sucked that bad. In the end I took 4 staples out of the press board box in the center rear storage compartment and folded down the front edge into the compartment. Easy access with socket and long extension. Bolt was out in seconds. Damage to press board material very minor and not visible when re-assembled.....Job done, sanity intact.
P.S.: I will be replacing interior soon. Any source for tips / instructions to avoid situations like this? Anyone ever written a guide etc.? I suspect it will be very trying on my patience when the time comes.
Old Feb 26, 2007 | 12:44 PM
kansas123's Avatar
kansas123
Hey that is a great trick, I will use that. Makes it easier, and besides, I think I lost the bolt anyway LOL
Old Feb 26, 2007 | 06:14 PM
Artsvette73's Avatar
Artsvette73
I did this once after i removed the rear compartment the nut wasnt a promlem. Before I put it back together I used a 3/4 leather punch to make a acess hole in the cardboard. Found a plastic plug. Now all I don't have to remove the whole rear compartment. Use a magnetic socket with an extension
Old Feb 26, 2007 | 06:36 PM
mikebaskette's Avatar
mikebaskette
Default I am glad
I am glad you asked the question about removing the console as I am having the same problem. Difficult question or not I am happy to see it
soooo thank you. Mike.
To Parking brake console removal help.
Old Feb 26, 2007 | 07:03 PM
Danny456's Avatar
Danny456
I used a nut driver and it was very simple to acess once i used a light to see where the head of the bolt was
Old Feb 26, 2007 | 08:03 PM
aussiejohn's Avatar
aussiejohn
Sure,
I buy most of my books from "Wheels of Time" bookshop in Clow Street, Dandenong, but I think you'll be able to find a source closer to New York. Try Mid America Motorworks, Zip, Bair's etc. Possibly Summit, but I've never bought from them.
aussiejohn
Old Feb 26, 2007 | 08:15 PM
#77's Avatar
#77
Yet another good idea. Thanks.
