81 driving problem
Old Feb 24, 2007 | 08:59 PM
nick80vette's Avatar
nick80vette
Default 81 driving problem
hi, i have a 81' with a 79 distributor and carburetor in it..before i switched over the the 79 carb and distributor it ran horrible and now that i have switched when i am driving after i get up to 35mph the enging will not rev up and and the car will not pass 35mph. does anyone know what causes this?
thanks,
-Nick-
Old Feb 25, 2007 | 05:29 AM
kevinator80's Avatar
kevinator80
Have you checked your accelerator linkage to make sure you are getting enough travel?
From your post I assume the car is running fine at idle and up to 35? Any other strange symptoms?
Old Feb 25, 2007 | 08:30 AM
sly vette's Avatar
sly vette
Is there still a catalytic converter on it???
Old Feb 25, 2007 | 09:09 AM
nick80vette
the car revs up when in neutral to 4000+rpms, how ever when driving, it only reaches about 1200-1500 rpm. w/ top speed of about 35 mph. it was doing the same thing before the carb/dist. swap. It does have a catalyic convert. exhaust gas is coming out the tail pipes so I was thinking are ok. got a brand new fuel pump also.
Old Feb 25, 2007 | 10:53 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Do you know if the vacuum advance is working properly?
Old Feb 25, 2007 | 11:07 AM
SIXFOOTER's Avatar
SIXFOOTER
Ahh, there is a clue, it was doing this before the swap.
couple things to verify;
#1 cat is not plugged up or mostly so
#2 Timing ring on ballances has not slipped
#3 proper indexing of the distributor
I would start with the timiong issues, then remove the cat and see what happens
Old Feb 25, 2007 | 11:17 AM
CA-Legal-Vette
I was thinking this initially as well but it revs in park. Shouldn't make a difference if it's plugged up should it?
Old Feb 25, 2007 | 11:34 AM
nick80vette
Idling @ 700, I have the timing set at 6 degrees BTC with vacuum advance hose plugged, is this correct?
when we pull the vacuum hose off the dist. there is a definite change in engine rpm. thanks for the ideas, will double check the timing
Old Feb 25, 2007 | 11:40 AM
sly vette's Avatar
sly vette
Read the stickey on timing at the top of TECH.
Old Feb 25, 2007 | 12:56 PM
CA-Legal-Vette
That may well be your problem or at least part of it.
Old Feb 25, 2007 | 01:44 PM
a1sensei's Avatar
a1sensei
This is one of the main reasons I encourage people not to dump the '81 CCC system the first time the car hiccups. If your car is not running correctly, diagnose the problem, don't just start replacing things. If it had the problem before, and you replaced the distributor and, I assume, made an educated attempt to set it up correctly, I doubt timing is the problem (two distributors, same timing issue: not likely). Get a GM service manual and start going through the diagnosis littany. God bless, Sensei
Old Feb 25, 2007 | 02:14 PM
MsVetteMan's Avatar
MsVetteMan
Is the computer still hooked up??? If so, unhook it!! 79 distrib. and carb won't work with it hooked up.......Also make sure your vac line is hooked up going back to the tranny........
Old Feb 25, 2007 | 06:37 PM
nick80vette
we adjusted the timing to the correct setting and that seems to have fixed the problem. I agree with 1sensei we spent some unneccessary money. thanks for all the input.
To 81 driving problem
