Rear spring assembly?
Old Feb 25, 2007 | 02:31 AM
cherrybombc3's Avatar
cherrybombc3
Default Rear spring assembly?
I cant seem to find the thread on this, though I know I've seen one.
Question is,
when "final" torqing the spring retainer to the diff @ 70 ft lbs, the car has to be lowered on the ground, correct??
I torqued them to 35 initially while in the air & now I'm ready to lower the car, or should I just put them right to 70 while in the air??
Old Feb 25, 2007 | 09:21 AM
SIXFOOTER's Avatar
SIXFOOTER
Most of the tome for a high torq or even moderate torq I step up to it, 35 first then 75, gives things a little settle in room. For the spring mount I don't know why you would need the weight on the spring for this. I eould just assemble it.
Old Feb 25, 2007 | 10:53 AM
elecriciandude's Avatar
elecriciandude
I just finished doing a new housing, spring,calipers and shocks. I torqued everything including the spring plate in the air. I did every bolt
in increments just for my peace of mind. With the 4 spring bolts you can re-check them after a few miles,Terry
Old Feb 25, 2007 | 05:17 PM
cherrybombc3
Thanks,
In the VB&P paper it says to torque to 70 then it has in parentheses * (de-arched) * I just thouught they were trying to tell me someting??
Old Feb 26, 2007 | 09:28 AM
70vert's Avatar
70vert
Banned Scam/Spammer
Do final torque with full weight on the spring. This will reduce the chance of cracking the diff. cover.
Old Feb 26, 2007 | 10:52 AM
cherrybombc3
Thanks, that's what I thought.
All done! whew, one month and she's all done. Now I need some warm weather.
To Rear spring assembly?
