Today, both the battery and choke lights came on at the same time .Car runs ok. The needle on the volt guage usually is to the right of "13".Now it's a little to the left.
Both warning lights go out at idle.
I would guess this is alternator related. Any suggestions for
troubleshooting ?
(My screen goes blank when I hit submit. Hope this won't be a dupe.)
Yep. Alternator has bad diodes. Drive to a local Oreilly and they can test the alt while it's in the car. Make sure you turn on headlights and blower fan and radio to put as much of a load as you can on the alt.
