383 stroker pinging ?
Old Feb 25, 2007 | 05:16 PM
allen80's Avatar
allen80
4th Gear
Default 383 stroker pinging ?
tried several things want to run on pump gas have pentroixn distbor also elderbrock performer heads compression 10.1 adjusted timing to 4 degree btdc medium size spings in distbuor.
Old Feb 25, 2007 | 06:15 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Old Feb 25, 2007 | 06:59 PM
evalu8r's Avatar
evalu8r
You want to look at your total timing, shouldn't be more than 36* at 2500 r's. I also have the pertronix flame thrower and was having trouble with a ping, you will probably need to adjusted your vacuum adv. canistor it was my problem.
Chris
Old Feb 25, 2007 | 07:00 PM
Gordonm's Avatar
Gordonm
Initial does not mean much. What is your total timing. Should be around 34 to 36 degrees
Old Feb 25, 2007 | 07:03 PM
BarryK's Avatar
BarryK
....adjusted timing to 4 degree btdc.......
initial timing setting is telling us nothing.
with the vacuum advance unit disconnected and the vaccum hose plugged what is the timing at when it's all in and at what rpm is the timing all in at?
you should be in the range of around 34º-38º total timing with it all in somewhere between 2800-3000rpm. (some people like to bring it in as soon as 2500rpm)
Old Feb 26, 2007 | 07:25 PM
allen80's Avatar
allen80
4th Gear
thanks for your help i have already adjusted vacuum advance but i go any farther i lose power. I not sure of my total timing will have to check that as soon as i get my car out. It runs good when i mix fuel but get to be a problem when going on long trip with my corvette club.
Old Feb 26, 2007 | 09:01 PM
randyredleg's Avatar
randyredleg
Does it ping as soon as you start driving or only after you have been on the road for 30 minutes or so and the engine is warmed up?
Old Feb 27, 2007 | 07:46 PM
allen80's Avatar
allen80
4th Gear
thanks for your reply yes after engine is warmed up most notice on hills with light load .
Old Feb 27, 2007 | 08:20 PM
randyredleg
Sounds like the problem I had. It would only ping after I'd been driving
30 minutes or so, and going up a hill it was definitely more noticeable.
In my case the vacuum line from the EGR was hooked up to the wrong
**** on the thermal vacuum switch.If working properly, the EGR cools things down.
Another thing to look at is whether the doors in the horns of your air cleaner are working properly.When you start up, hot air is pumped in through that foil hose on the left side. The doors stay closed initially, but then should open up. The hoses from the horns work off a vaccum, which is controlled by a temp switch.
If you go to autozone.com and type in your vehicle type, you can find diagrams and explanations of these systems.
Old Feb 27, 2007 | 08:23 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Run it without the vacuum can and see if pings uphill with light load
To 383 stroker pinging ?
