Yep It's broken AGAIN!!!
Old Feb 26, 2007 | 11:54 AM
mdjice's Avatar
mdjice
Default Yep It's broken AGAIN!!!
I had to walk 45 mn to go home (my wife works too far to come back) and My car is stuck at a Gas station...
Other then that it's a very pretty day in Houston!!!
Car would not hold the idle, i tryed to adjust it but he would just die at every stop sign or light.
I Went and got some gas, car started afterwords and as I was exiting the station, te engine stoped and now no way to get it to start again. t's not the battery, the engine doesn't crank i tried giving it gas...or not it doesn't even sound like it's gonna start.
Things I've noticed the GEN light was on each time the car died on me and it s on when I try to stat the car. Also....I have a little bit of white smoke coming out of both exaust. I took the Air claner off and when I try to start the car I can see Fumes/ smoke coming out of the carburator....
If you don't know about my car...It's the 3rd engine in it since i got it 8 months ago (stock, new and rebuilt)
HELP??
Old Feb 26, 2007 | 12:52 PM
bashcraft's Avatar
bashcraft
What do you have for ignition?
Old Feb 26, 2007 | 01:08 PM
mdjice's Avatar
mdjice
what do you mean?
starter is new, alternator is rebuilt else on ignition is stock
Old Feb 26, 2007 | 01:13 PM
bashcraft's Avatar
bashcraft
Do you have points or a HEI? Did you verify that it still had spark? I know this is almost impossible to do by yourself.
Old Feb 26, 2007 | 01:25 PM
mdjice's Avatar
mdjice
I have HEI No i didn't check that I will though. Anything else?
Old Feb 26, 2007 | 01:43 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
did you check if you have spark?
Did you check if fuel is actually flowing during cranking?
Maybe the distributor/coil or fuel pump is bad...
The fuel filter could be clogged etc. etc. etc..
Old Feb 26, 2007 | 01:45 PM
69autoXr's Avatar
69autoXr
The Gen light was on before it died? Or after is had already died? Have you verified the alternator is actually charging? The way I read it sounds like the alternator is dead.
Old Feb 26, 2007 | 01:53 PM
rihwoods's Avatar
rihwoods
Try this...clean your main harness connector next to your distributor....
Just un-plug it and use electrical contact cleaner....you may get lucky..
Another: If it started right up cold..and you had nada after it was warmed up on restart,it could be the starter solenoid...just bump engine with a screwdriver at starter..then jump in and try starting it...
Rich
Old Feb 26, 2007 | 01:58 PM
Hvymtlc5's Avatar
Hvymtlc5
If you pour some gas in the carb ( be careful) will it start? If it does, fuel pump may be gone.
Old Feb 26, 2007 | 02:03 PM
Little Mouse's Avatar
Little Mouse
its still turning over but won't start. you said you put gas in it ran
enough to try and leave the station then died again.
mdjice's Avatar
mdjice
ok thanks ama try all that
Old Feb 26, 2007 | 02:09 PM
rexx78's Avatar
rexx78
If the engine doesn't crank, and the gen light is on, that sounds like a dead battery. As mentioned earlier, is your alternator charging?
Do your interior lights or headlights work?
Old Feb 26, 2007 | 02:29 PM
Little Mouse
sounds like the battery was still turning it over but pumping the
gas pedal or just turning it over and over it will not start.
Old Feb 26, 2007 | 02:35 PM
Big2Bird's Avatar
Big2Bird
It is very normal for this light to be on when the engine is stopped, or during cranking.
Old Feb 26, 2007 | 02:36 PM
bashcraft's Avatar
bashcraft
Or getting close to stalling.
Old Feb 26, 2007 | 02:38 PM
Big2Bird's Avatar
Big2Bird
This is the part that would concern me most.
Old Feb 26, 2007 | 03:02 PM
rihwoods's Avatar
rihwoods
need to make a list...
To Yep It's broken AGAIN!!!
Old Feb 26, 2007 | 03:14 PM
GrandSportC3
Another thing that could be the problem is a blown power valve or a sticking needle (if you are using a Holley carb)
Old Feb 26, 2007 | 07:06 PM
mdjice's Avatar
mdjice
I'm using a edelbrok carb.
I got it towed and the shop told me it was a pice of my Distributor just being ol and not working.
$90 to fix it
Old Feb 26, 2007 | 07:51 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
I'm sorry, but after that 22 page fiasco about your engine being dead, you seem like a "woe is me" person here. If you need a car to get to and from work, go buy a used civic. All your posts are "help!!"
To me, you just sound like a guy asking for pity, constantly. Fix the car (i.e. pay someone), and move on.
