Guldstrand solid bushings installed.
Old Feb 26, 2007 | 06:00 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Default Guldstrand solid bushings installed.
Go them from redvetracr
I put them in right, right? I'm wanting to get a speedway bar like norvals. Im thinking 2 inch should be good. The bar cost 185dollars Hopefully I can find a cheap used one.
Old Feb 26, 2007 | 07:12 PM
68 NJConv 454's Avatar
68 NJConv 454
That is the front a-arm right? looks weird in the pic.
Can't tell you if its in right as I don't know much about the solid bushings.
What speedway bar are you speaking of? a spreader bar?
http://www.vbandp.com/detail.aspx?ID=532 $100
or does that speadway bar have to do with the spindles and rideheight?
Old Feb 26, 2007 | 07:33 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
3Pc. sway bar
Old Feb 26, 2007 | 07:43 PM
norvalwilhelm's Avatar
norvalwilhelm
This is my speedway bar. It is 1 1/4 inch, splined on the ends for the arms and look at the solid bushings. No deflection here. I also run rod ends for a solid flex free linkage and at the same time no binding. It run me close to $400 by the time I was done
Old Feb 26, 2007 | 08:42 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Did you have to bend your arms? Also what arms did you use? Can't seem to find any like yours.
I'm going to try and get everything used but the pillow boxes and arms I may not find.
What width bar are you running?
Old Feb 26, 2007 | 10:02 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
those are the exact same bushings i have.
installing them at the recommended 10 o clock position gives some additional negative camber. That's what i did on the driver's side. The passenger side only had one shim in so i was afraid i'd have too much negative even with no shims so i installed them straight up 12 o clock.
I redrilled the grease zerks on the upper arms on the passenger side after realizing you just can't get at them as designed.
Did you tack weld them in? I tacked the uppers and lowers.
Oh, they didn't provide enough machine bushings (washers). You want to be able to torque the end bolts to spec without the bolt head and washer touching the bushing, otherwise it would bind. You don't want too much space because the a arm will move around on the shaft under loading.
Old Feb 27, 2007 | 03:14 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
How easy do your bushings turn? Mine are kind of difficult to turn with my hand.
Old Feb 27, 2007 | 08:52 PM
turtlevette
they turn by hand fairly easy. Did you grease the shaft?
Did you check everything i mentioned?
Old Feb 28, 2007 | 07:46 AM
norvalwilhelm
Originally Posted by GDaina
When installing headers by yourself, it's a PITA, lining up the bolts, keeping the gasket from sliding...etc, etc.
Tip....get a bunch O rings that slip over the bolts....line the gasket to the flange, slide the bolts through, slip the rubber O rings on the bots. The Orings keep the gasket from moving. Now you can line up the header and get the bolts started. Once you fire the motor, the rubber O rings will melt.
Where did this come from????
Old Feb 28, 2007 | 08:37 AM
GDaina's Avatar
GDaina
Daaaaaaaaaaaaaaaaaaah....should have been a seperate thread.....long day, long night...brain dead when posted.....
To Guldstrand solid bushings installed.
