adjusting new hyd lifters
Old Feb 27, 2007 | 07:39 AM
dmaaero's Avatar
dmaaero
Default adjusting new hyd lifters
I got several books and they all have different methods for adjusting new hyd lifters. Actually i dont think none of em know what there talking about!!!! As long as the lifter is on the base circle (off the lobe ) can i adjust them at that point?
Old Feb 27, 2007 | 07:53 AM
panchop's Avatar
panchop
last couple engines I put together with hydraulic lifters I just tightened them till I I hit spring pressure,then went another turn. Then as soon as I started the motor I backed each one off till I heard it clattering and brought it back to zero. When I was done with a side I turned it off, took up a half turn, ( or a quarter depending on what engine I was on ) and went and did the same thing on the other side.
Old Feb 27, 2007 | 08:09 AM
BLACK SHARK's Avatar
BLACK SHARK
From: In the shop most of the time,,, And it BEER TIME somewhere
http://www.compcams.com/Technical/In.../Files/145.pdf
Old Feb 27, 2007 | 09:00 AM
dmaaero's Avatar
dmaaero
ok i got it now, chevy"s dont turn the same direction as dodge"s do when there running! sorry guys been around dodges a little to long i guess. Did you know if your turning the motor over backwards , when the exhaust valve starts to move the intake is still half open
Old Feb 27, 2007 | 09:56 AM
lars's Avatar
lars
All American engines rotate in the same direction.
Old Feb 27, 2007 | 11:01 AM
Big2Bird's Avatar
Big2Bird
Maybe he lives south of the equater.
Old Feb 27, 2007 | 11:59 AM
dmaaero's Avatar
dmaaero
That darn hemi gets you confused every time!!!!
Old Feb 27, 2007 | 12:03 PM
S489's Avatar
S489
i heard a rumor that "smokey" built one to run backwards (ccw looking from front) for a nascar race: nail it - left side digs down instead of up. but nascar outlawed it so it never ran a race. not sure if story is true . . . always wondered
Old Feb 28, 2007 | 01:48 AM
stingr69's Avatar
stingr69
I would agree - they are all nuts!
Snug them ALL a half turn past zero up-down play, rotate engine 360 degrees, snug down the ones that are now loose. It makes perfect sense but nobody believes me. Been doing it that way for years but I do not advise anyone else to do it. It only works for me.
-Mark.
Old Feb 28, 2007 | 03:40 AM
L88Plus's Avatar
L88Plus
I always get #1 to TDC on compression stroke, adjust both valves at the same time. Turn the engine over 1/4 turn, then adjust #8. Continue around the firing order until you're done. This way, you're sure not to miss anything. I adjust mine 1/2 turn past zero lash, it's always worked fine for me.
Old Feb 28, 2007 | 08:44 AM
Edzred72's Avatar
Edzred72
Just some info that might help::
I have a Crower hydraulic roller. Crower recomends .030 to .060 lifter preload. At zero lash, I put a dial indicator on the pushrod end of the rocker and slowly tightened till it read .045 (middle of recomendation). It took 1/2 turn plus another 1/8 (5/8 turn)
1/2 to 3/4 turn is all I would tighten yours.
Eddie
Old Feb 28, 2007 | 09:32 AM
dmaaero's Avatar
dmaaero
I went with the one cylinder at a time method,rotate engine when the exhaust starts to move adjust the intake,rotate engine when the intake completely opens and is almost closed adjust the exhaust. Works fine if your turning the engine the right direction!
To adjusting new hyd lifters
