Almost fixed...but not!
Old Feb 27, 2007 | 01:16 AM
lorijones's Avatar
lorijones
Default Almost fixed...but not!
My horn was contantly hot and I found that the harmonica wiring from the new turn signal switch got "smooched" when tightening the steering column. SO the 1st black wire was grounding. Okay fixed that and reinstalled everything except the upper horn contact and cap. Still good....but every time I screw down the horn contact...constant horn blowing. Any ideas?
Old Feb 27, 2007 | 01:28 AM
lorijones's Avatar
lorijones
One more queston... when installing does the horn conact protruding prong push down on the horn brush all the time? Maybe I'm installing wrong.
Old Feb 27, 2007 | 05:45 AM
LYLE's Avatar
LYLE
The plastic pins may be the problem also you could need more shims. The pin should be on the spring loaded part.
Old Feb 27, 2007 | 08:26 AM
ShaneLU97's Avatar
ShaneLU97
Can you elaborate? I am having a similar problem....
Old Feb 27, 2007 | 01:43 PM
LYLE's Avatar
LYLE
Their are three plastic pins in that top assembly and if they are broken and cause a ground the horn will honk all the time.
Old Feb 28, 2007 | 12:36 AM
lorijones's Avatar
lorijones
I understand about the "pins" what look like plastic rivets but I do not have any shims at all.
Old Feb 28, 2007 | 09:51 AM
LYLE's Avatar
LYLE
I never seen a column that had 0 shims they usally have two or three shims so this may be the problem.
To Almost fixed...but not!
