Front Spoiler vs Airdam
Old Oct 8, 2001 | 08:54 PM
MikeT's Avatar
MikeT
Default Front Spoiler vs Airdam
Alright guys....Which puts more air up into my radiator, Spoiler or Airdam??? What's the difference???
Old Oct 8, 2001 | 09:25 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Re: Front Spoiler vs Airdam (MikeT)
Here's a better question. Which is cheaper to replace? AIRDAM....... Spoilers look great, but are pricey to replace.
To answer the questions, I would guess it is relative to the amount of air that can flow through the radiator. You can only push so much air through a tight space at highway speed...
Old Oct 8, 2001 | 09:51 PM
KenSny's Avatar
KenSny
Default Re: Front Spoiler vs Airdam (Budman78)
Since our cars are mostly chin breathers the air dam helps to channel some of the air going under the car up into the radiator. The front spoiler is there to disrupt air from going under the car at high speeds to keep the front end from lifting. If you travel at really high speeds don't get rid of the spoiler (you don't want to start flying) if you want good flow thru the radiator keep the air dam. If you want to look fast standing still keep the spoiler.
Old Oct 8, 2001 | 10:53 PM
IT STINGS's Avatar
IT STINGS
Default Re: Front Spoiler vs Airdam (KenSny)
I love my spoiler and I do believe the spoiler along with the dual electric fans keeps the rad cool (hardly ever past 200 even on really hot days):yesnod: . However I've managed to scrape up the front tip and I've torn out the spoiler from either side of the wheel well from different highway road debris encounters :mad But I can't deny I love the way it looks.
Old Oct 9, 2001 | 12:37 AM
villare's Avatar
villare
Default Re: Front Spoiler vs Airdam (IT STINGS)
Can you tell me what kind of hood do you have it looks higher than the original
Old Oct 9, 2001 | 11:13 AM
UKPaul's Avatar
UKPaul
Prior to buying my '81 I did some reading up on differences between the years. The airdam was added to increase airflow around the radiator to aid in cooling. It seems to work as my '81 has only gone past 200 once (it rarely ever reaches 200, but who can trust the temp gauge?). There is only a certain amount of air that can go through the radiator, but lots of fresh air flowing around the engine bay also helps cool things down (is this why the '81 hood has no heat insulation on the underside?).
Paul
To Front Spoiler vs Airdam
