Guys
all of a sudden I am getting a bit of run on - when I turn the key off it does not immediately stop...seems to want to continue to run for several seconds and then dies out - any suggestions on what to check
Agree,..your primary throttle blades are too open at idle and not idling only on the idle circuit as it should. If your initial timing is too low, you're likely compensating with an idle setting that's too high and causing the dieseling.
The reason run on is also called dieseling is because it is runing without ignition. Idle speed doesn't matter, you could be running WOT, if the ignition is turned off you have no spark and the engine will stop as fast as friction will allow under normal operating conditions. Dieseling is caused by hot spots in the combustion chamber along with compression igniting the fuel/air mix without spark. Detonation is basicly the same thing but occures while the engine is running, it is defined as uncontrolled ignition. Common causes are any sharp areas on the piston such as around valve reliefs or the spark plugs themselves overheating.
GG,..agree, but without fuel which continues to get sucked in to the combustion chamber after ignition shut-off, there will be nothing to light off. Shut off the fuel supply (by reducing the primary throttle blade opening so that it's idling on the IC not the transition circuit) and dieseling won't happen.
some other thoughts: look into everything to do with tuning as already suggested. also check all of the pollution equipment, especially the egr valve. when egr valve sticks usually closed, engine runs richer and lots of black soot/carbon can build up over time in the combustion chamber, the back of intake valves, etc. twidling with the idle to compensate for this and other issues can get your run-on. my 74 with auto had an idle soleniod, but it is to compensate for the A/C. evidently some have said theirs is set up to eliminate run-on. if done this way by factory, maybe depends on tranny??? thx
Originally Posted by Godfathers Ghost
The reason run on is also called dieseling is because it is runing without ignition. Idle speed doesn't matter.
That's not correct. GM had severe run-on problems starting in the early 70s on brand new cars. The problem was solved by installing idle-up solenoids on the cars. The solenoid dropped idle speed and closed the throttle when the engine was shut off to eliminate the run-on problem. The GM tech bulletin that we received at all the dealerships instructed the mechanics to lower idle speed on cars with run-on complaints, and this consistently solved the problem. You can induce run-on by shutting a hot engine off at elevated engine rpm.
Very verry true...I experience that with my 69 502/Holley occasionally.Hot days are worse...sometimes I sit there till rpm's drop....then turn the turkey off...
