Stuck Door
Old Feb 27, 2007 | 05:02 PM
ray76's Avatar
ray76
3rd Gear
Default Stuck Door
reciently bought a '76 vette but i cant seem to get the passenger door open. key turns, interior lock moves, interior door handle moves, door doesnt open. is there a way to trick the latch??
Old Feb 27, 2007 | 09:33 PM
Durango_Boy's Avatar
Durango_Boy
You have some linkages out of alignment or your door latch assembly is worn and won't function any more. To get it open, you'll have to peel back the top of the door panel a little bit. Using a flashlight and a LONG flathead screwdriver, push down on the part pointed to in the following pic. Get a good solid push on it and the door will pop right open. The tip of the screwdriver may slide off so stay at it. Trust me it works.
After the door is open, tape up the guide on the bulkhead, and take off your door panel. You may have to replace the door latch assembly, and yes, they are cleanable but that doesn't always mean it's going to work
If you do buy a new one...don't get the cheap Chinese stuff...get a good $80 unit from Ebay or a vendor.
Old Mar 1, 2007 | 03:52 PM
ray76's Avatar
ray76
3rd Gear
Default thanx
wow i didnt expect pics, u guy rock!!
Old Mar 1, 2007 | 04:14 PM
Durango_Boy
No problem. Just let us know if it works.
To Stuck Door
