Hooker Header Installation
Old Feb 27, 2007 | 10:04 PM
Oklahoma Academy's Avatar
Oklahoma Academy
Default Hooker Header Installation
headers in before or after?
We are about ready to put the new 350 engine in the '77 Vette project. The owner bought Hooker side mounts for it. Should we install the headers after the engine is in or before? Normally, this is a no-brainer, but since they are chrome and beautiful, we would be taking a chance on damaging them while installing the motor if we lay them in first and the put the engine on top. However, it could also be that it is not possible to install them afterward, or we would be taking just as big a chance of damaging them trying to squeeze them in. Any thoughts?
Old Feb 27, 2007 | 10:22 PM
BLACK SHARK's Avatar
BLACK SHARK
From: In the shop most of the time,,, And it BEER TIME somewhere
Hang them in the engine bay with some wire, bungi cords, rope, ect. Let them hang loose while you drop the engine in place. You will find this much easier than trying to put them in after the engine is in.
Old Feb 28, 2007 | 06:52 AM
Oklahoma Academy
Thanks. I figured as much, but you never know...
Old Feb 28, 2007 | 07:42 AM
1B.DZ's Avatar
1B.DZ
As an extra precaution, you could wrap them in something so they wont get knocked into something that could scuff or scratch them. That would be my luck, that's why I'm suggesting.
Can you supply some pics of this project?
Josh
Old Feb 28, 2007 | 02:25 PM
Oklahoma Academy
I am going to take some pics today.
Old Feb 28, 2007 | 02:31 PM
Big2Bird's Avatar
Big2Bird
Old Feb 28, 2007 | 02:56 PM
Gunn353's Avatar
Gunn353
Agree with the above. It was a PITA for me to put on my hookers after the engine was already installed. Still possible, but too much hassle.
Old Feb 28, 2007 | 04:52 PM
gyopp's Avatar
gyopp
I think the easiest is to install engine, headers, exhaust, and then put the body on the car
Old Feb 28, 2007 | 07:59 PM
Oklahoma Academy
Here's the engine. 350, 4 bolt main, bored .030, stock crank and rods, 10:1 flat tops, Holley heads, Too much cam for an automatic with high gears ( Lunati 235/240), too much carb (Holley 750 street HP). Blatant, loud and nasty. Very pretty, though...
Old Feb 28, 2007 | 08:10 PM
BLACK SHARK
That looks great,,,Drive it up here so I can see it when its done,,,,
Old Feb 28, 2007 | 09:23 PM
vho69's Avatar
vho69
as long as you can get the car high enough, about 18 to20 inches, there very easy to install after the motor is in from the bottom
Old Feb 28, 2007 | 10:52 PM
King Lear's Avatar
King Lear
Veteran
I second that, it was the biggest test of patience I have had trying to get those headers in from up underneath and then the header bolts were the icing. Lots of beer to get that job done! Not to mention you have to have the thing 3 feet in the air to get them in from underneath.
Definitely put them in and to the side before you drop the engine, leave them in the factory wrapping.
Old Feb 28, 2007 | 11:57 PM
jdmick's Avatar
jdmick
I'd install them after. It really shouldn't be that hard. I managed to reinstall my headers and sidepipes as one unit after an engine swap. The two were rust fused together so I didn't have any choice. Maybe this article will help.
http://www.corvettefever.com/howto/4680/
Old Mar 1, 2007 | 12:46 PM
C3 4ME's Avatar
C3 4ME
Just installed mine last weekend and no problem from underneath. Now, my Hooker Super Comps are not sidepipe headers so maybe that makes a difference. I did have to have the clutch Z bar, & #3 plug out on the drivers' side. On the passenger side, the A/C has to be off, because the bracket bolts through the front of the header, and the starter had to be out. None of the above do I consider a big deal.
Old Mar 1, 2007 | 02:19 PM
King Lear's Avatar
King Lear
Veteran
Side pipes are a huge difference. The header is one long piece from the exhaust manifold down to a 90 bend, then out to the door, then another 90 degree bend going back even with the doors where the collector meets the 4" side pipe. You have to do some twisting and turning and have it high enough in the air to move them around and wiggle them in. If you have a car lift then great probably would be easy. In your garage with a floor jack is a different story.
Old Mar 1, 2007 | 03:01 PM
alanbl's Avatar
alanbl
I currently have the heads off, and all related hardware and I'm going to be installing Hookers with sidepipes. If I hear you right, it sounds like my best bet is installing them from underneath the car. Or, is it easier to thread them from above since the heads are off?
Old Mar 1, 2007 | 03:14 PM
King Lear's Avatar
King Lear
Veteran
You might be able to do it since the heads are off. I did it twice with the heads on. It is impossible to go from above with the heads on. Try it with the heads off, the passenger side might go, but I doubt the drivers side will with all the steering components.
To Hooker Header Installation
Old Mar 1, 2007 | 03:28 PM
alanbl's Avatar
alanbl
Thanks. Just looked at your profile. '72 Steel Cities Gray - Nice! (Obviously I'm biased.)
Old Mar 1, 2007 | 03:35 PM
King Lear's Avatar
King Lear
Veteran
thanks, that reminded me to change my avatar back, hard to find many SCG cars anymore.
Old Mar 1, 2007 | 07:33 PM
Bimmervet's Avatar
Bimmervet
St. Jude Donor '12-'13-'14-'15-'16
Glad you asked this question, I will be doing the same here in Chicago as soon as it warms up. April???
