Harmonic Dampers
Old Mar 1, 2007 | 07:05 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Harmonic Dampers
So I have a fluidampr, but I was reading the SCAT catalog and they seem fairly adamant about not using fluid type dampers.
So what is the real deal?
Old Mar 1, 2007 | 08:45 PM
BB72's Avatar
BB72
Default I was told
You can't balance a motor with a fluid damper on, you have to use the stock one. I guess that means you can switch afterwards.
Old Mar 1, 2007 | 09:30 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I have an ati
Old Mar 1, 2007 | 11:19 PM
Scott Marzahl's Avatar
Scott Marzahl
Some of the bracket racers I know say the Fluidampers are only good for about 1-2 years. They only use ATI's.
For a street car, just use a high quality unit like a stock GM nodular iron or Pioneer Nodular iron piece.
Old Mar 1, 2007 | 11:47 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
I went back through the archives researching this problem for my own engine. The consensus seems to be that for the street, a bigger heavier damper is better. I got a Pioneer 8", 10lbs.
Old Mar 2, 2007 | 07:18 AM
Guru_4_hire
Cruise-In V Veteran
I am building a forced induction motor, does that change anything?
What is it about fluidamprs that fail?
Old Mar 2, 2007 | 01:14 PM
S489's Avatar
S489
i'd like to hear too. i got a fluidampr based on their clain that it will not wear out like the factory style. and if kept to a reasonable rpm, the factory type lasts a long time . . .
Old Mar 2, 2007 | 01:18 PM
Gordonm's Avatar
Gordonm
I have run a Fluidamper on mine for 6 years now and 2 motors. No problems at all. It sees 65 to 7000 rpm quite a lot.
What is supposed to go wrong with them?
Old Mar 2, 2007 | 02:01 PM
BLACK SHARK's Avatar
BLACK SHARK
From: In the shop most of the time,,, And it BEER TIME somewhere
I have had a Fluidamper for 10 years, no problems. Its been to 8000 rpm many many times. Also, someone said he didnt think you can balance an engine with a fluid style balancer on. I think you can. They are not liquid filled, but have what they call a rubber elastometer[I think] in them, But might not sell very good if that is what you called it.
Old Mar 2, 2007 | 02:02 PM
Little Mouse's Avatar
Little Mouse
I have not owned a fluidamper on a car. but I have put millons of
miles on diesel truck engines they have fluid dampers on them.
I have a hard time believing one would fail on a car.
Old Mar 2, 2007 | 02:06 PM
jackson's Avatar
jackson
http://www.bhjinc.com/
The best in "conventional" elastomer dampers. Also lotsa great shop tooling.
Old Mar 2, 2007 | 04:02 PM
Gordonm's Avatar
Gordonm
The Fluid dampers are neutral balanced therefore do not require balancing like a stock balancer does. You cannot balance a Fluidamper. Balance the motor without it and put it on and forget about it. It works. There are others out there that work just as well but I can't figure why Scat would say not to use them. Unless they build or sell one of the other dampers.
Old Mar 2, 2007 | 04:15 PM
Guru_4_hire
Cruise-In V Veteran
In other threads I can find, it has to do with their 9000 material.
Everything I can find says balance it with a stock damper and then put on the fluidampr.
Old Mar 2, 2007 | 08:53 PM
ZL1powr's Avatar
ZL1powr
I don't personally have any experience with fluid dampers but my machinest who builds a lot of racing engines for the local circle track guys, won't use a fluid damper. He has experienced broken cranks that he attributed to the fluid damper.
Old Mar 2, 2007 | 09:01 PM
Superstock's Avatar
Superstock
I have used an ATI superdamper on six or seven race motors shifting @9500 and crossing @ 9800-10000 rpm and never experienced any issues .
Old Mar 3, 2007 | 05:23 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I think he has other issues if he's breaking cranks, a fluid damper is a perfectly valid concept technically unless he is running the cranks at such a high rpm that the tuning of the fluid dampers may not be optimum. All dampers are compromises depending on speed (i.e. frequency) ... if you want the best for any application, you have to get the correct one for your operating speeds.
I agree that you don't want the fluid damper on the engine during balancing. They are nutral balanced from the factory unless you have an externally balanced engine, then they come with the counter weight which DOES need to be installed (ONLY the counter weight and not the whole damper).
Old Mar 3, 2007 | 08:39 AM
Big2Bird's Avatar
Big2Bird
To Harmonic Dampers
