Shut off valve
Old Mar 1, 2007 | 08:21 PM
nutseynut7's Avatar
nutseynut7
Default Shut off valve
What hose do you put the shutoff valve to stop flow to heater.Hose to manifold or one to water pump
Old Mar 1, 2007 | 08:25 PM
68 NJConv 454's Avatar
68 NJConv 454
you mean visegrips
Someone will be able to answer you, what shut-off valve are you using?
Old Mar 1, 2007 | 08:32 PM
nutseynut7's Avatar
nutseynut7
mean valve that you put in heater hose to stop the water flow in summertime to heater core, they are available in the heater supply places Saw that some people have installed them but dont know which hose it should go on
Old Mar 1, 2007 | 10:44 PM
Artsvette73's Avatar
Artsvette73
The 5/8th heater hose.
Old Mar 2, 2007 | 01:56 AM
PortDawg's Avatar
PortDawg
St. Jude Donor '05
NAPA Part number is 660-1414
Old Mar 2, 2007 | 03:12 AM
noonie's Avatar
noonie
Hose to manifold
Old Mar 2, 2007 | 06:34 AM
nutseynut7's Avatar
nutseynut7
Old Mar 2, 2007 | 09:18 AM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
Or you could just bypass your heater.(it's easier) You can buy a bypass adapter(plastic)for less than $5 at any auto store. It has a 3/4 on one end and 5/8 on the other. No cutting required, use the clamps you already have.
Larry
Old Mar 2, 2007 | 09:23 AM
Jims79's Avatar
Jims79
Originally Posted by noonie
Hose to manifold
that's the one. just so you don't make a mistake its the top hose. You can get a shutoff valve at home depot or lowes in the plumbing dept. you will also need a four inch copper pipe threaded on both ends which fits the S-off and the size of the 5/8 hose. Cut the pipe in half and use hose clamps on either side of the S-off. Works great no more unwanted heat.
Old Mar 2, 2007 | 07:18 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
[IMG][/IMG]
[IMG][/IMG]
Old Mar 2, 2007 | 08:31 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
It maybe all in my head, but when I just closed off one hose (the one from the intake manifold), I still could feel some heat coming from under the dash....but when I closed off the other hose, the heat stopped.....
Old Mar 2, 2007 | 08:48 PM
Superstock's Avatar
Superstock
I used both quick open valves and nipples ( like Bob's photo ) except I painted black and mounted down low near firewall next to heater core out of sight .
Old Mar 2, 2007 | 08:50 PM
Superstock's Avatar
Superstock
Buy the threaded nipples w/ lip for better fit .
Old Mar 2, 2007 | 10:42 PM
lucky76's Avatar
lucky76
Put one on each hose.
Old Mar 3, 2007 | 08:20 AM
kb2fzq's Avatar
kb2fzq
Some people do both, I valved only the hose that was input flow to the core and it works fine, no more heat in the cockpit during summer....I used a PVC hot water heater valve, it works fine, less weight then brass, painted it black with hi temp spray paint...I guess, pick your poison, valve it or connect both hoses in a loop, they will both work
Old Mar 3, 2007 | 02:23 PM
Superstock's Avatar
Superstock
I installed one on each hose in case my 34 yr. old heater core started leaking at an inoppertune moment. Well sure enough last summer I found droplets on the floor mat and blocked it in . It is still closed for now .
Old Mar 5, 2007 | 07:05 PM
68 NJConv 454
Threads like this cause my small parts pile to grow, I have the urge to go to home depot and buy two valves and i don't even have my engine rebuilt and installed.
Home depot it is!
To Shut off valve
Old Mar 10, 2007 | 11:06 PM
lucky76's Avatar
lucky76
Home depot it is!
I don't know why some people try to reinvent the wheel. They sale these cutoffs at most auto supply stores, no reason to go to Home Depot and buy valves and fittings. Go to and autosupply store and say "I need a 5/8 inch and a 3/4 inch heater hose cutoff valve."
Old Mar 10, 2007 | 11:44 PM
noonie's Avatar
noonie
What language did they answer you in?
Old Mar 11, 2007 | 12:10 AM
MN-Brent's Avatar
MN-Brent
Be sure to check the temp limits on those Home Depot valves. I think they are something like 140F, not 195F.
Brent...
