Electric choke wire voltage ?
After my engine swap I am only getting 1.7 volts and the electric choke is not opening, no matter how long I wait.
Let me know what readings you have on yours.
Thanks.
Does anyone have an idea as to why my choke wire voltage would be low.
It should be off the "ign" circuit and 12 volts , possibly a broken wire
with some voltage not the fuse. So wire to connector connection or
just go back along the wire till you hit the full 12 volts . The old fashioned way of finding it thats what I'd do. Or lay in a new wire off the "ign" terminal off the fuse block, probably the quicker fix of the two.
Scott
[Modified by Scott78, 6:56 PM 10/9/2001]
firewall and to the fuse box, solved the problem.
Don't use the wiper motor I mucks up you wipers. :D
What does it do to the wipers to muck them up? I've been using the wiper motor terminal for about 2 years without any problems. Do I need to pick another spot to get power?
Thanks for all your help, I have eliminated the bad ground and have traced the entire wire back to the block. It has 1.7 volts the whole way. I am going to stop using it, cut and crimp it off and do what I said above.
The cause of mine was the P. circuit behind the gauge cluster. I have an oil temp gauge instead of the standard whatever (clock?). The P. circuit for the original gauge had just been bent up & allowed to rest against the rear of the oil temp gauge. Where it had been vibrating/moving for 20 years, one of the tracks had broken at the point of the fold in the P. circuit. This track was something to do with the gauge lights & may have explained the Gen light. Not sure about the choke problem though. I also found that the copper tracks on the P. circuit at the main connector position had lifted away from the circuit & were possibly shorting across the connector, or not contacting at all. I glued them back onto the circuit & then cleaned the copper up with very fine wet or dry paper. I also did this for the Speedo/tach P. circuit connector tracks. This solved the problem. Also use a multimeter to check continuity of all the tracks (remembering that the bulbs & gauges will make live have continuity to ground). Fix any broken tracks with jumper wires & low melting point solder (don't buy a criminally expensive new P. circuit!).
I drew a circuit diagram of the choke/gen wiring & can send you a copy if you need one (it took me 2 evenings & an entire weekend to fix this problem, so I got to know it quite well
). I can also measure the correct current to the coil now that it works (so chuffed to have fixed it I didn't bother seeing what it was, I just put the air filter back on & went for a blast!).If voltage/current checks out OK at the choke heater relay then I'd recommend (very strongly!!) pulling both clock & gauge clusters out. If I'd done that originally then I could have saved a myself a weekend & evening of lying upside down in the drivers seat with a multimeter, circuit diagram & some strong language ;)
If you need any extra help, email me. Hope this makes sense - the boss keeps walking in which makes it difficult to keep track!
:cheers:
Paul
