jumpy at light throttle
Old Mar 3, 2007 | 02:22 PM
soccer794's Avatar
soccer794
Default jumpy at light throttle
Just installed my new 750 dp...wow I feel like I'm driving a whole new car. That being said, I can tell it still needs a little tweaking. If I'm on the throttle even a decent bit its fine, and if I'm completely off the throttle its fine, but if I'm just barely on the throttle its very "jumpy." Seems a little like a lean condition, but I need some advice. What should I check/adjust? Its on a 454 if that matters.
Old Mar 3, 2007 | 07:41 PM
soccer794's Avatar
soccer794
ttt
Old Mar 3, 2007 | 09:52 PM
marshrat99's Avatar
marshrat99
Fuel starvation on light throttle? Have you checked the float levels? How about the choke, is it opening up all the way? We need more info.
Old Mar 3, 2007 | 11:01 PM
Thinpockets's Avatar
Thinpockets
Make sure that the accelerator pump linkage is tight with no slop. If the throttle plates start to open before it gets a squirt it will hesitate. It may be just a little bit out but when it starts sucking air it needs fuel also. If you slam it to the floor it makes little difference but if you ease it down it will stutter.
Old Mar 4, 2007 | 10:29 AM
soccer794's Avatar
soccer794
Checked the float levels and adjusted them, no choke. I assume its fuel starvation, but I'm not sure. I just know it kind of "bucks".
Old Mar 4, 2007 | 10:48 AM
76 sting's Avatar
76 sting
Check you timing. I had the same issue, but a little more than jumpy and re adj the timing and went away 100%
To jumpy at light throttle
