Putty looking stuff in door jams
Old Mar 3, 2007 | 05:22 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Putty looking stuff in door jams
Stripped the door jams today and some of the putty looking stuff came off. What is it? It's behind the hinge area. Looks like a couple of different compounds. What can I patch it with?
Old Mar 3, 2007 | 08:23 PM
bondoboy's Avatar
bondoboy
That's seam sealer. You can get it in a caulking tube or in a quart can.
Old Mar 3, 2007 | 11:35 PM
7T1vette's Avatar
7T1vette
I think the right stuff to use is butyl caulk. You can find it at the major hardware outlets. Glossy black is a good match from the original stuff. Make sure the surfaces are good and clean and the caulk should last the next 35 years. (I would not recommend that you use silicone caulk.)
To Putty looking stuff in door jams
