Valve seal How-To
Old Mar 3, 2007 | 10:23 PM
TheMongoose's Avatar
TheMongoose
Default Valve seal How-To
Is there a how-to posted anywhere on replacing the valve seals in my stock L48 (1976)? Can I do this without removing the heads?
Old Mar 3, 2007 | 10:25 PM
Big2Bird's Avatar
Big2Bird
It can be done. It's a PITA though.
Old Mar 3, 2007 | 10:30 PM
Gordonm's Avatar
Gordonm
It is not that bad to do. Yes you can do it without removing the heads. You need a tool to remove the valve springs and somethng to hold the valves while the keeper and spring is off. Compressed air in the cylinder works the best. It takes some time because you are doing all 16 valves but you should be able to do it in an afternoon. If you have done it a few times it should take a few hours.
Old Mar 3, 2007 | 11:19 PM
sdonnelly's Avatar
sdonnelly
http://forums.corvetteforum.com/show...ht=valve+seals
To Valve seal How-To
