Trans Cooler Install Say WHAT!!!
No temp differences to quote. I put it in soon after I put in my 200-4R with 2200 stall converter. To be honest, it worked fine before the cooler and worked fine after. Not pushing much HP through it. Just a stock motor.
I ended up blowing the tranny in one week,but not due to any heat buildup. It was one 6500 rpm shift from second to third. I have a TCI temp guage,and it never went over 170. In fact after I had the trans rebuilt,I ran it a year with the same cooler,again blew the trans,and still never over heated it.
I give up on the 700r4,but I guess I'm pushing a tad more than 350 hp.
) to see how high I could get the fluid temps. Never got the coolant over 200 & the trans fluid never got over 170 (that test was fun
).BTO told me that the ideal operating temp for trans fluid is 160F. I've said that several times here & it seems to be ignored, or argued against. In the absence of any other values I'll assume that 160 is correct, so I don't think fitting the largest cooler possible & keeping the trans fluid out of the rad would be a good idea as it will get cooled too much. Over cooling is not a problem with the coolant as there's a stat in the system to maintain a minimum temp, but the trans fluid hasn't got that luxury (unless you view the stock system as doing the same job by keeping the fluid warmed by the coolant). If keeping the fluid as cool as possible is the ideal, then why did GM pump it into the rad & not a dedicated cooler???
My cooling system is in good condition, with a re-cored rad, new hoses, new intake, new stat & a block flushed as much as I could. Real world testing by cruising at 130mph for a few miles, followed by a longer period of 120mph cruising did not increase coolant or trans fluid temps significantly (don't know what rpms I was turning, I didn't dare take my eyes off of the road more than I had to!). Mine seems to run slightly cooler than others with the same setup, but that's probably due to the 80-82 front end pushing more air through the rad?
I'm not saying the way I've done it is the best way, but it works for me. Something worth thinking about is the fact that if I start it from cold, drive 2 miles to the nearest motorway, stick in OD with the converter locked & then sit at about 80mph (2000rpm) it will take at least 10 miles before the trans fluid gauge will even hint at moving off of the bottom mark (100F). If I wasn't passing the fluid through the rad then I expect that it would take even longer to warm up (or not at all) &, if there really is a prefered minimum fluid temp, that wouldn't be good for it.
Last edited by UKPaul; Mar 6, 2007 at 12:12 PM. Reason: temps of 200 - 200 didn't make sense!
