383 Build How does it work
They rev fine too!
JIM
I would suggest either 383 or 400. The 383 would be a killer high RPM high HP engine, and the 400 would be a torque monster.
RPM limitations are not what they used to be 20-30 years ago. So the whole idea of short stroke high revving motors are just for bench racers and dreamers. IMO there is no real reason to exceed maybe 7500 rpm for a street driven vehicle. The cost to make valve train that can reliable run over 7500 rpm turns into big bucks. Not to mention the rotating assembly.
A smart person would use a blower on a small block or just jump right into big blocks
Engine Bore Stroke
Chevy 262 4.000 3.480
Chevy 327 4.000 3.250
Chevy 267 3.500 3.480
Chevy 305 3.740 3.480
Chevy 350 4.000 3.480
Chevy 355 (.030 over 350) 4.030 3.480
Chevy 357 (.040 over 350) 4.040 3.480
Chevy 360 (.060 over 350) 4.060 3.480
Chevy 400 4.125 3.750
Chevy 406 (.030 over 400) 4.155 3.750
Chevy 409 (.040 over 400) 4.165 3.750
Chevy 377 (400 block, 350 crank, .03 over) 4.150 3.480
Chevy 334 (305 block, 400 crank, .03 over) 3.770 3.750
Chevy 383 (350 block, 400 crank, .03 over) 4.030 3.750
Chevy 414 (400 block, 3.875 stroker crank) 4.125 3.875
Chevy 420 (400 block, 3.875 crank, .03 over) 4.155 3.875
Chevy 427 (400 block, 4" stroker crank) 4.125 4.000
Chevy 434 (400 block, 4.000 crank, .03 over) 4.155 4.000
