roller cam - cam button question
Old Mar 8, 2007 | 03:49 PM
Belgian1979vette's Avatar
Belgian1979vette
Yep, but they take these things apart every race, something I don't want to do. I don't their cams wil be usable anymore.
Yves
Old Mar 8, 2007 | 04:12 PM
gkull's Avatar
gkull
Instead of denting the timing cover I have seen guys that braze on a button and then just repaint the timing cover.
The cloyes aluminum is @ $110 USD
The Comp Cams nice two piece that i have on one of my motors is about $200
As i said the cloyes took alot of hours to make it work. I had to machine the top front and also the roller button face about .050 to give it clearance with my Crane gear
As a side note. most aftermarket aluminum water pumps come with an adjuster nut fron the pump to the front timing cover to support the center for roller cams
Old Mar 17, 2007 | 11:25 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Here is a good article detailing why correct endplay and a cam button are so important: http://www.chevyhiperformance.com/te...r_cam_endplay/
