454 truck engine
Old Oct 9, 2001 | 11:49 PM
paso's Avatar
paso
Default 454 truck engine
Awhile back someone was thinking of installing a 454 truck engine into thier vette. I was wondering how they made out. I know most truck engines had the tall deck and four bolt mains. but cubic inch is cubic inch I ran across a 73 3/4 ton pickup with only 63,000 miles (was used as a family camper truck) also has the turbo 400 tranny for $750.00 might be a good swap candidate for a few years of fun. reasonable winter project What do you think. :U
Old Oct 9, 2001 | 11:52 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: 454 truck engine (paso)
My engine was once a truck engine. I don't think it is any taller than others.
Old Oct 9, 2001 | 11:58 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
The tall block engine usually was found in BIG trucks and buses, not pickups or Suburbans. You can check out which block the motor has by looking at the casting numbers and going to http://www.mortec.com and looking for which blocks are "tall" blocks. There is a very good chance that your truck engine is a normal height block.
Old Oct 10, 2001 | 09:00 AM
Ganey's Avatar
Ganey
Reg. truck engines are normal height. Heads badly needed.
Old Oct 10, 2001 | 09:26 AM
GWHITE75's Avatar
GWHITE75
I have just removed a "truck" block from my car. It is about 1/2" taller than a passenger block. These truck blocks came from older big trucks and larger commercial type vehicles. I had no real clearance problems with it. Everything above the block will be a little higher. This will affect some mounting brackets, header fit and location. You will need to modify a couple of brackets. A taller deck height allows for more stroke. My motor was stroked and bored to 496 CI. If you are wanting a truck block to get more cubic inches, then this could be a cheaper way to go. Otherwise, I would stay with the standard 454 set up and spend the same money on good modifications.
Old Oct 10, 2001 | 09:47 AM
GaryS's Avatar
GaryS
If you find a block with a proper part number your 454 block will be the same configuration and dimensions as a Corvette engine.
Gary
To 454 truck engine
