Monospring and Shock combinations?
Old Mar 7, 2007 | 11:27 AM
DeeVeeEight's Avatar
DeeVeeEight
Default Monospring and Shock combinations?
I would like to know what combination of Monospring and shock absorbers you are using on the rear of your 'Vette and how you like the performance of the combination. I am trying to figure out how to get my suspension to work for highway cruising, street cruising and occasional drag strip use.
TIA!
Old Mar 7, 2007 | 12:05 PM
1B.DZ's Avatar
1B.DZ
What I plan on doing is running the VB&P Monospring with my KYB GR2 shocks. I think they are suppose to be used with Monosprings anyway. Hopefully I'll get this put on in the next month or two and be able to post a full report. I hear a lot of people run the bilstein Sports with their Monos and have had some luck with them.
Josh
Old Mar 7, 2007 | 01:50 PM
panic's Avatar
panic
TIA!
i have front transverse monospring kit (from ecklers), rear composite shortened monospring and QA1 all round.
It works!
Old Mar 7, 2007 | 02:19 PM
DeeVeeEight
It works!
QA1 ??? What are those? And what is your rear spring rated at?
Thanks!
Old Mar 7, 2007 | 03:30 PM
Gordonm's Avatar
Gordonm
Bilsteins all around on front and rear with mono springs at both ends. Great shock for street use.
Old Mar 7, 2007 | 04:59 PM
panic's Avatar
panic
Thanks!
one of the best shocks for our cars....
dont know what rate but they're pretty hard.
Old Mar 7, 2007 | 06:57 PM
SmokinBBC's Avatar
SmokinBBC
Panic, I like the new Avitar!
QA1's are close to $200 each...not neccessary for a DD or weekend cruiser IMHO.
Old Mar 7, 2007 | 08:14 PM
DaveL82's Avatar
DaveL82
Can't beat QA1's for tunability per dollar. If the car were to be setup and not changed for other types of driving their not needed.
Old Mar 7, 2007 | 08:46 PM
tellcom2001's Avatar
tellcom2001
i bought the slolem set from vbp that came with rear mono leaf spring. bilstein shocks all 4. both sway bars front and rear..way better then stock.car can turn a corner on a dime and holds the road great even over bumps..and the price was good
Old Mar 8, 2007 | 12:34 AM
panic's Avatar
panic
[QUOTE=SmokinBBC;1559270786]....Panic, I like the new Avitar!
here is a larger version....
it's my week end ricer punisher
Old Mar 8, 2007 | 03:23 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
Not sure if you are interested in a C2 setup but I am running a 460# front and 300# rear composite. Spax external adjustable shocks. I like it. Nice ride and I can turn the shocks up in less than 5 minutes if I want to stiffen it up for the twistys.
Old Mar 8, 2007 | 05:58 PM
DeeVeeEight
Sure I'm Interested, thanks for chiming in, and
NICE CAR!
Old Mar 8, 2007 | 06:28 PM
alanbl's Avatar
alanbl
This was my first mod. I have a 330# monospring from VB&P and I took Panic's advice about the QA-1 shocks which I think ran about $135 each, not $200. It was a great move! I've been able to adjust the stiffness of the shocks to get the perfect combination of ride & handling. And, the handling improved exponentially which is important since I live on a steep, twisty mountain road. Changing lanes at speed on the highway is no longer an adventure either.
Panic is also a great source for wine recommendations! I believe that's due to his Italian genes.
Old Mar 8, 2007 | 10:04 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
I have the VB&P mono springs front and rear with Edelbrock IAS shocks on my 72. Handling and ride are great.
Old Mar 8, 2007 | 10:17 PM
rjken1969's Avatar
rjken1969
I have 550lb/in coils in front and a 330lb/in mono in rear, with KYB GR-2 shocks all around. Only problem is I still have to install all of it. Hopefully this is as easy as it seems.
Old Mar 8, 2007 | 10:22 PM
rjken1969's Avatar
rjken1969
By the way Panic, I love your ride, bad a$$. I like the Repsol sign in the background too. We don't have those here in the US. But we do have Nicky Hayden, for the motorcycle fans....
Old Mar 16, 2007 | 09:28 AM
VBP's Avatar
VBP
St. Jude Donor '07,'13
Default Qa1 Shocks
Thanks for the feedback on the QA1 shocks. This is a new product for us and I like to hear what you all say so I can recommend them if necessary to those who may need them.
Any feedback on any of our parts is always welcome.
Thanks again guys,
Pattie
VBP
To Monospring and Shock combinations?
Old Mar 16, 2007 | 10:03 AM
SmokinBBC's Avatar
SmokinBBC
Thanks again guys,
Pattie
VBP
Pattie,
I could not find the QA1 on your site. What's your pricing for the 68-82 front and rear?
Paul
Old Mar 16, 2007 | 08:34 PM
Jason Staley's Avatar
Jason Staley
Do you experience any of the bounciness common with the rear mono springs?
I've tried alot of shocks and the only ones I have found that ride good is the KYB2's from VBP. The only problem is they are a little soft for driving hard. From the description of the IAS shocks by Edelbrock and Ricors patent (19 pages total ), they sound like the best of both worlds for a street/strip car.
Old Mar 16, 2007 | 09:38 PM
Thinpockets's Avatar
Thinpockets
I have the VBP mono springs front and rear. The rear is 330 lb. with KYB GR2 shocks. This is a great cruiser ride but for more spirited driver I would go with Bilstein or QA1.
I drive across a bridge with concrete surface and the Corvette handles the bounce a lot better than my Sierra pickup.
