Proportioning valve
Old Mar 7, 2007 | 12:05 PM
1313's Avatar
1313
Default Proportioning valve
where is the proportioning valve on a 75 located and how hard is it to change out ....thanks in advance for your help
Old Mar 7, 2007 | 12:24 PM
pws69's Avatar
pws69
There isn't one. Are you having problems?
Old Mar 7, 2007 | 01:31 PM
1B.DZ's Avatar
1B.DZ
There isn't one? What is it called then? I'm confused now. I thought the brake lines went off of the MC to a PV then out to the brakes. Clue me in please.
Josh
Old Mar 7, 2007 | 01:45 PM
crazywelder's Avatar
crazywelder
Originally Posted by 1B.DZ
I thought the brake lines went off of the MC to a PV then out to the brakes. Clue me in please. Josh
This is somewhat correct.
It's a distribution valve technically. It's mounted to the frame below the master cylinder. It's not a quick job because you'll need to bleed the brakes afterwards. The rear line has a couple clamps to the frame behind the valve that need to be disconnected. New GM parts are still plentiful and available for under $100.00, stay away from the rebuilts.
Is yours leaking?
Old Mar 7, 2007 | 01:55 PM
pws69's Avatar
pws69
Josh
Josh,
ahoover stated it well.
Proportioning valves are used when the hydraulic pressure requirements between 2 systems [front/rear] are very different - most notably systems with DISC front / DRUM rear brakes. You need to set the proportion [balance] such that one system doesn't grab and subsequently lock up before the other.
Old Mar 7, 2007 | 02:05 PM
1313's Avatar
1313
had tranny resealed (good neighborhood shop) note on bill that proportioning valve was leaking losing brakes...got one from forum member Gary.G. want to do it myself but am at a loss...
Old Mar 7, 2007 | 07:00 PM
Duke94's Avatar
Duke94
Actually there is a proportioning valve on 75'. Prior to 74', they just had a "pressure differential valve" which basically is the switch that turns on the red brake light on the dash, The valve is mounted on the frame rail below the master cylinder and looks like this.
Old Mar 7, 2007 | 07:22 PM
nihil's Avatar
nihil
I am here to cause more trouble and confusion
Why was a switch made from a differential valve to a proportioning valve? Did GM decide there needed to be a difference in braking pressure to the front/rear disc brakes, or was it done for super extra safety in addition to the two-reservoir master cylinder?
Old Mar 7, 2007 | 07:23 PM
Roscoe's Avatar
Roscoe
Old Mar 7, 2007 | 07:32 PM
rabiddawg's Avatar
rabiddawg
thats called a combo valve not a proportioning valve or distribution valve.
basically senses drop in pressure between front and rear brakes.
sends more pressure to the fronts than the rear brakes etc.
its pretty much all the mentioned valves rolled into a single unit.
I was extensively schooled in it just recently.
lol a mechanic set me straight during my disc brake upgrades on my 69 camaro
Old Mar 7, 2007 | 07:46 PM
Duke94's Avatar
Duke94
Uncle Sam made them do it (it was called FMVSS-105). Basically, you gotta stop in a certain distance (don't remember the requirement any more) and have to stay within a 10 foot wide lane. The "Combo Valve" (aka "differential/proportioning valve) stopped the rear brakes from locking up before the fronts in high decel stops due to weight transfer. If the rears lock first, you will tend to swap ends.
Old Mar 8, 2007 | 08:11 AM
1B.DZ's Avatar
1B.DZ
Thanks for the lesson guys I don't think mine needs replacing, but I will assess that when I get to it. I will be replacing everything else, so I probably will do the same with this part. Apparantly it was the only other piece of the brake puzzle that WAS functioning properly. The rear flex lines both had a huge air bubble in them, so when I hit the brakes the Red light came on. I had no idea what it meant at the time, just thought it was telling me I was hitting the brakes, lol.
Thanks again guys,
Josh
Old Mar 8, 2007 | 08:48 AM
Edzred72's Avatar
Edzred72
.... note on bill that proportioning valve was leaking losing brakes...
Valve is one piece brass. Other than it being cracked (Highly doubtfull) or the flares damaged (mabey), the only place it could leak are at the brake line connections. Your trouble might be the bake line fittings not perfectly square/tight to the valve. Very important to get the hard line 90* to the valve flare before tightening. Check there first.
Eddie
Old Mar 8, 2007 | 11:49 AM
Duke94's Avatar
Duke94
Eddie
The place they leak (assuming you have the prop valve as shown in above post) is at the vent hole on the flat of the end plug. It is protected by a rubber disc and held in with a finger washer. When the o'rings on the spool wear out (the spool inside the end plug, not the piston shown here) the fluid will leak at this vent. You can see the black disc in this photo. Check this area on yours.
Old Mar 9, 2007 | 10:48 AM
1313's Avatar
1313
Thanks for all your input .. will take a look this weekend..weather is finally going to break ...
Old Mar 10, 2007 | 08:15 AM
theoUK's Avatar
theoUK
Interested in this at the moment, as I've just had the combination valve apart on my 80, as part of a brake system refurb...
Duke94, it's essentially identical to the one you have pictured.
Now, correct me if I'm wrong, but to my understanding this valve provides no proportioning function, but simply acts as a differential pressure sensor, ie it turns the red light on when pressure is lost in either front or back sytems.
Is the braking force not "proportioned" simply by using smaller pistons in the rears?
There may be something I'm missing here but I can't see how the pictured valve /mine can provide any difference in pressure between front and rear systems.....
Old Mar 10, 2007 | 08:43 AM
Duke94's Avatar
Duke94
This valve DOES have proportioning. Yes, the pistons are smaller in the rears to help brake balence, but the proportioning valve was needed to meet the government FMVSS-105 stopping distance requirements. See my post above. The actual proportioning parts are inside the end plug, shown in this picture. Basically a spool with 2 seals and a spring. The "seat" that closes and establishes the proportioning function is the rubber piece in the end of the diff piston.
To Proportioning valve
Old Mar 10, 2007 | 11:25 AM
theoUK's Avatar
theoUK
Aha! Yep, I was missing something
I rather naively assumed that there was little of interest inside the end plug, and that it was just some form of extension adapter or something.
From the parts I saw in front of me, I couldn't work out how there could possibly be any proportioning action when there were no springs to create the proportioning effect. Seeing that makes a lot more sense, thanks for the picture. Yet again the forum's timing is spot-on!
How does the end of that plug come apart? I saw there are two smaller holes either side of the main hole (on the inner face) - do you put a pin-spanner in those and turn, or is there some other method?
I'll have to go and have another good look at it now
cheers!
Theo
Old Mar 10, 2007 | 12:12 PM
Duke94's Avatar
Duke94
The part with the spanner looking holes is press fitted into the endplug.
Old Mar 10, 2007 | 01:04 PM
theoUK's Avatar
theoUK
I see.
I guess you did well to remove this without damage then? How did you get it out?
Thanks!
