Anyone running a Holley Stealth Ram
Old Mar 9, 2007 | 01:24 AM
austvette's Avatar
austvette
Default Anyone running a Holley Stealth Ram
Has anyone installed a Holley Stealth Ram. I have a 1981 with a Hi-Rise hood and wanted to know if it would fit.
If anyone is running a Holley Stealth Ram can you tell me what mods you had to do if any.
Thanks.
Old Mar 11, 2007 | 03:12 AM
austvette's Avatar
austvette
Anyone
Old Mar 11, 2007 | 08:30 AM
Fevre's Avatar
Fevre
Have one on my Formula but that is a whole diff car, problem you might have with the hi-rise hood is it is set up for a carb(s) center over the intake while the throttle body on the HSR is over the front of the end of the eng so the hi-rise hood might not be high enough where you will need it. Try over in the C4 section for exact measurements or stealthram.com.
BTW it is a good over all intake; it provides almost the same low end grunt as a stock TPI intake and delivers the same upper end power as a short runner LT1 intake
To Anyone running a Holley Stealth Ram
