1980 Windows alignment
Old Mar 10, 2007 | 09:59 AM
tomard's Avatar
tomard
Default 1980 Windows alignment
My next task is to get both door windows aligned ..... after reading some posts on the issue, I am pretty sure what I need to do, but will put this out there to get some REAL experts' advice
The problem: the windows when rolled up when driving +50mph, do not seal and have quite a visible gap. Have to slow down/stop to roll them up and get a decent seal. The windows can be rocked back/forth about 1/2 inch or so.
I have ordered some new anti-rattle cushions that will require to take both doors apart, but have also heard that there might be something on the window motors that can be involved?
What should I check while I am in there replacing the cushions to get the glass properly secured?
Old Mar 11, 2007 | 07:23 AM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
tt
Old Mar 11, 2007 | 08:51 AM
SIXFOOTER's Avatar
SIXFOOTER
Sounds like the window rollers are done also. Go ahead and take 1 door apart, take pics as you go. Thuroghly clean all the tracks and inspect the rollers.
Clean and healthy they look like this;
http://www.ecklers.com/find.asp?
replace the worn ones and reinstall the window/tracks/regulator. Lube with White Lithium grease.
CorvetteFAQ has a procedure for the adjustment.
Old Mar 11, 2007 | 09:29 AM
MN80Vette's Avatar
MN80Vette
There was nothing found when I clicked on that link. Can you post the pic?
Old Mar 11, 2007 | 09:45 AM
tomard's Avatar
tomard
Default Replacing rollers
It does look like the rollers are allowing the window (only looked at drivers side so far) to rock side to side ..... I found replacement rollers on madvet.com (3 per window), but has anyone actually replaced these before?
I need some detailed help on this one, doesn't seem like enough room to really do anything inside the door, so I am assuming that I have to remove the glass, then motor and finally the regulator??
Also what do I need to SECURE the new rollers so that I don't have the top of window EVER move outward again (inward is taken care of by the two anti-rattle cushions)......
Old Mar 12, 2007 | 07:39 AM
MN80Vette's Avatar
MN80Vette
Here's a pic of everything in the Hurst kit.
They sell a Corvette look-alike **** and shaft available too, but I just used the Hurst shaft and bought a T-handle.
Old Mar 12, 2007 | 08:01 AM
SIXFOOTER's Avatar
SIXFOOTER
There are blow out clips on the A pillar in the weatherstrip to keep the top from moving out. I can't remember what order everything comes out, but that might be correct, motor and regulator can come out together but be carefull, it can bite you. There is a hole in the regulator to put a safety bolt in to keep it from unwinding if you need to take the motor off.
To 1980 Windows alignment
