Vibration - Driveshaft????
Old Mar 10, 2007 | 08:18 PM
PairOf80s's Avatar
PairOf80s
Default Vibration - Driveshaft????
Lookin' for a little help here. I had the rear end out of my 80 L82 to have the bearings and seals changed. Okay, that wasn't the original reason I pulled the rear end (everyone all together now) "while I was there anyway I decided to" have that done. I had new U-joints installed in the driveshaft and both propshafts.
Now that I have it all back together I have a vibration. It seems like a higher frequency vibration. I tried the trick of rotating the driveshaft 180 degrees and reconnecting to the rear axle. It seems like the vibration changed but it's still there. To be honest, I'd like for someone to explain why this would make a difference. Would it also make a difference if I swap the driveshaft front to rear? If I remember correctly the automatic cars used the same U-joint on both ends.
Or do I just need to have the balance on the driveshaft checked? Does this need to be done whenever U-joints are replaced?
Old Mar 10, 2007 | 08:41 PM
C3Racing's Avatar
C3Racing
St. Jude Donor '07-'08
You have this problem before you had the seals and bearings done?
Old Mar 10, 2007 | 08:49 PM
PairOf80s's Avatar
PairOf80s
No, I didn't. I did have another vibration due to tires with flat spots but I've changed those out now too.
Old Mar 10, 2007 | 09:00 PM
C3Racing's Avatar
C3Racing
Maybe the half shafts got mixed up from left to right and or they got flipped around (what once was outer now installed towards the diff.)
Old Mar 10, 2007 | 09:31 PM
PairOf80s's Avatar
PairOf80s
Actually, that's likely. I don't understand why it would make any difference...which is why I didn't mark any of the shafts when I removed them.
Old Mar 10, 2007 | 09:47 PM
b71vette's Avatar
b71vette
Call a local Commercial Truck Repair shop, ask for a recommendation on a Driveline Shop. take all three in and have them "zer0-balanced". Don't except "balance is within specs".
Old Mar 10, 2007 | 10:07 PM
PairOf80s's Avatar
PairOf80s
I've already had a driveline shop recommended to me by someone I trust. Looks like it's back up on the jackstands!
What would cause the shafts to get thrown out of balance? Just by changing the U-joints?
Old Mar 10, 2007 | 10:17 PM
C3Racing's Avatar
C3Racing
""Maybe the half shafts got mixed up from left to right and or they got flipped around (what once was outer now installed towards the diff.)""
That can throw them out of balance..
Old Mar 10, 2007 | 10:25 PM
PairOf80s's Avatar
PairOf80s
I guess I'll be pulling the shafts out again. Thanks so much for the help!
Old Mar 10, 2007 | 10:31 PM
C3Racing's Avatar
C3Racing
Allways mark the drive shafts before remouval,, that way you know where they go back from the factory.
Old Mar 11, 2007 | 12:51 AM
7T1vette's Avatar
7T1vette
My guess (and that's what it is..) is that one of the U-joints is in a bind. It's pretty easy to over-stress a yoke and put it out of alignment, if you're not careful about removing the old ones (rusty, stubborn). If you are removing the shafts anyway, see how freely the U-joints swivel, etc. before you go to the trouble of balancing shafts. Also, GM never balanced anything on the vehicle; all individual components were balanced separately...so that the end result was "in tolerance". Multiple-section driveshafts can be installed out-of-phase, but one-piece shafts can't be [as far as I know].
Old Mar 11, 2007 | 12:56 AM
Big2Bird's Avatar
Big2Bird
Yes. Take the tranny yoke with you. They will balance it and give you a mark where to assemble it. It's the driveshaft. Halfshafts are so short, they won't cause the trouble that the driveshaft will. But have them checked.
Old Mar 11, 2007 | 05:48 AM
TFitz's Avatar
TFitz
if the u joints were pounded out as opposed to being pressed it is very likely there is a bind in one of them.they must swivil freely. a simple fix if you find the one is to press the shaft end back so the u joint will move freely.imo. tom
To Vibration - Driveshaft????
