Wiper Motor problems
Old Mar 10, 2007 | 09:33 PM
Fl_Mike's Avatar
Fl_Mike
Default Wiper Motor problems
Installed new wiper motor.Old motor was grounded with a wire from wiper motor housing to a bolt near hood latch. I removed the rigged wire and now motor will not run. I tested it with my test light and the whole wiper assembly is HOT even the blade arms have juice running through them.
Any ideas? The connection from the harness has three wires green,yellow,black.
Also high speed is not working.
When grounded to motor with rigged wire motor runs, but smokes a little which is not good.
Any ides why the past owner would of done this?
Old Mar 10, 2007 | 11:49 PM
SIXFOOTER's Avatar
SIXFOOTER
sounds like the connector not wired correctly, hot on the wrong pin
