Still Not Low Enough
Old Mar 10, 2007 | 11:31 PM
strokervette's Avatar
strokervette
Default Still Not Low Enough
Now that I got my insurance and reg I was able to drive around a bit to try and settle the front springs but they didn't budge. I'm just under 30" on the Pass side and 29 1/2" on the drivers side. I cut a tad past 1 3/4 coils on the drivers side and a tad past 2 coils on the pass side with the #213 moroso trick springs to try and even it out. I noticed that these springs' diameter are smaller than the stock springs and I think that they are not fully sitting in the pockets. I even rounded off the tops of the top coil thinking it would seat better but it didn't. I even left the sway bar off because it seems that it binds up things.
Should I cut another half a coil on both sides or what?
Old Mar 11, 2007 | 10:41 AM
'Bochawa72's Avatar
'Bochawa72
Got any pics?
-CR
Old Mar 11, 2007 | 11:00 AM
strokervette
Drivers front
[IMG][/IMG]
Passengers front
[IMG][/IMG]
If I cut more, the pass side gets it the most because its a half inch higher right now. Right after breakfast I'm going out there and going to cut 3/4 of a coil off pass side and 1/2 coil off of drivers side. I'll let everybody know what happens.
Old Mar 11, 2007 | 11:52 AM
Gordonm's Avatar
Gordonm
What have you got to lose. The springs are already cut so keep going. I would make surethey are seated in the spring pockets.
Old Mar 11, 2007 | 01:09 PM
White 68's Avatar
White 68
If I were you I,d buy the used set of 550,s in the for sale section He,s asking 40 bucks and will put you closer then 29.5
Old Mar 11, 2007 | 05:04 PM
enkeivette's Avatar
enkeivette
550s should put you just above 27.
Old Mar 11, 2007 | 06:24 PM
Glassbowtie77's Avatar
Glassbowtie77
I'm at 27.5" with my 550's, I think the the height is perfect. I would get the 550's if you don't mind the slightly harsher ride.
Old Mar 11, 2007 | 08:10 PM
strokervette
Well thanks for the advise guys, but I did manage to get my desired ride height today. I ended up cutting one more coil off of each spring and now I'm at 27 3/4 at each side. I'm really happy now that both side are even. The springs were probably not in the pockets correctly because I wasn't cutting an entire coil off at a time, I just couldn't get the thing to seat otherwise. I was a little nervous at first to cut a whole coil but it ended up being just right. It looks like the tire is in the wheel well a little too much but nothing rubs and I am getting 245/60 front tires next anyway. And 255/60 in the rear. Thanks again!
Old Mar 11, 2007 | 10:35 PM
strokervette
Here are a few pics taken today at a local Auto Zone. I needed a hose for the overflow tube.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Mar 11, 2007 | 10:37 PM
The3's Avatar
The3
Does it rub?
sorry, reread your post above.
To Still Not Low Enough
