Some people are extraordinarily blessed!
Old Oct 10, 2001 | 09:21 PM
jsimpson's Avatar
jsimpson
Default Some people are extraordinarily blessed!
I drove by a 67 427 today with it's right front wheel laying on the road, and a wrecker hooking up to the coupe. Now just what percentage of his driving time do you figure he's traveling at less than 20mph? He had just pulled away from the light when the spindle broke! I shudder to think of the alternative situations. Reminds me of the time I was pullling up to a traffic light and my lower ball joint fell loose on my 914-6. Just the day before, I was.....I don't even want to think about it! God is indeed good!
Old Oct 10, 2001 | 10:03 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: Some people are extraordinarily blessed! (jsimpson)
He is watching, even when things seem to not be all that great.
Old Oct 10, 2001 | 10:41 PM
daily_driver's Avatar
daily_driver
Default Re: Some people are extraordinarily blessed! (71,454,4spd)
his front spindle????
hmmmmm
what scares me about my 76 is that if one of my rear spindles goes then im dead.
i just dont have the money to get the van steels tradeins....
maybe one day.......
:crazy:
Old Oct 11, 2001 | 12:22 AM
tsw71's Avatar
tsw71
Default Re: Some people are extraordinarily blessed! (daily_driver)
I know that lucky feeling. One night when I was about 20, I was two blocks away from getting on the freeway for one of my daily high speed runs in my 71. As I approached a stop sign, I heard a loud bang and the right rear of the car dropped to the ground. The outer mount of the half shaft where it bolts to the rear spindle broke. Had it happened 2 minutes later, I'm am sure it would have been much more serious. :eek: :eek: :blueangel:
I also broke the rear spring about a year later. Again, it was at very low speeds :blueangel:
Old Oct 11, 2001 | 12:35 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
hmmmmm
I had a front spindle let go on a '74 El Camino while doing 65 MPH, and pulling my motorcycle on a trailer. The front wheel folded up in the inner fender and the car went into the center ditch.
Next day and $600 dollars later, we drove back home. New spindle, rotor, caliper, upper and lower ball joints, tie rod ends and brake line.
No other damage to the car, including the fender !!
Was caused by a wheel bearing locking up.
Grease those suckers !!
Old Oct 11, 2001 | 12:43 AM
daily_driver
Default Re: Some people are extraordinarily blessed! (BSeery)
oh no dont start mentioning bearings!!!!
im gonna have a nightmare tonight about my rear wheel bearings....
grinding..... twisting...... metal shavings....
blahh
:cry :cry
Old Oct 11, 2001 | 07:12 AM
73Ken73's Avatar
73Ken73
I had a rim shatter right after I got off of the highway. It was a slotted Aluminum American Racing rim on a 75 Monte Carlo. I had been doing 100 mph on the highway about 5 minutes earlier.
Old Oct 11, 2001 | 09:50 AM
zwede's Avatar
zwede
Default Re: Some people are extraordinarily blessed! (73Ken73)
I had a fiberglass rear spring break. Amazingly it broke with the car parked in the garage! I remember hearing a noise around 10PM, but didn't think to check the car (after all, it was safely parked in the garage. What could happen?). Next morning I went down to the car to go to work and noticed it had turned into a low rider.
I'm now running a steel spring. :)
To Some people are extraordinarily blessed!
