Trailing arm shims
Replacing the trailing arms and wheel bearing assembly's on my 70 vette. never done these before, but have everything off at this point, with new ones on the way. Question,........The shims that were on these arms were not like the one's Ive seen pictured in parts books or on line. Instead of being open, or slotted on one end to make it possible to slide them in place after bolt is loosly installed, both ends have a hole to stick the bolt through. Thought this was stange. Also had no cotter pin at lower end which I guess would not be neccesary with this style of shim. Might these shims be original factory ones. Just curious.
Replacing the trailing arms and wheel bearing assembly's on my 70 vette. never done these before, but have everything off at this point, with new ones on the way. Question,........The shims that were on these arms were not like the one's Ive seen pictured in parts books or on line. Instead of being open, or slotted on one end to make it possible to slide them in place after bolt is loosly installed, both ends have a hole to stick the bolt through. Thought this was stange. Also had no cotter pin at lower end which I guess would not be neccesary with this style of shim. Might these shims be original factory ones. Just curious.And yes, they're a PITA. That's why GM went to the slotted shims. You only need the non-slotteds if you're doing a 100-point factory restoration.
Since removing the TA bolt is a PIA with the body on, I made sure I got the stainless steel slotted shims from VBP with my suspension kit.
The slotted ones will allow the alignment shop to adjust much easier. I drilled a hole in the frame pocket and bought a long cotter pin to secure the shims. I believe the later C3's came from the factory with the slotted shims and hole in the frame.
Stainless slotted shims are the way to go!
