Wiper Door Alignment 69
Old Mar 11, 2007 | 09:38 PM
SoCalErv's Avatar
SoCalErv
Army
Default Wiper Door Alignment 69
Just recently my wiper door has shifted from the passenger side to the drivers side. I have a large gap on the passenger side and almost no clearance on the drivers side. I see two screws that look like adjustment of some sort. Before I go nuts and tear it apart can someone give me an overview of adjustments that can be made, both level to the car and clearance on the sides. I have a service manual but I didn't see much there.
Old Mar 12, 2007 | 08:24 AM
jnb5101's Avatar
jnb5101
i just installed my wiper door on my 70 rebuild. i noticed that the coil helper spring had shifted off the seat about 1/4 inch so the mounting holes for the grill didn't line up with the holes on the transmission. put it in a vise and tapped it into position. hope this helps.
Old Mar 12, 2007 | 01:30 PM
7T1vette's Avatar
7T1vette
Good idea. Also, lube up the linkages, etc. and do whatever you can to get it working [U]without removing the wiper door bolts[U]. Removing (and likely breaking) those bolts is the beginning of "evil" repair problems. Hopefully, you can get it working without removing it.
Old Mar 12, 2007 | 01:31 PM
7T1vette's Avatar
7T1vette
Good idea. Also, lube up the linkages, etc. and do whatever you can to get it working without removing the wiper door bolts. Removing (and likely breaking) those bolts is the beginning of "evil" repair problems. Hopefully, you can get it working without removing it.
To Wiper Door Alignment 69
