Removing Side Yokes
Old Mar 12, 2007 | 01:48 PM
bbvette69's Avatar
bbvette69
Default Removing Side Yokes
I have removed the rear cover on the differential and also removed the c clips holding the side yokes but they only move a little bit and wont slide out of the housing.Do they need to be forced or am i missing something.
Old Mar 12, 2007 | 01:53 PM
BB72's Avatar
BB72
Default It sounds like
the ends of the yokes are worn a bit causing the inside spline to have some burrs on it. I would just take a soft face hammer or cover it with a rag and use a ball peen hammer and tap it out. It should come out slowly.
Old Mar 12, 2007 | 02:25 PM
wombvette's Avatar
wombvette
Get a bigger hammer.
Old Mar 12, 2007 | 04:23 PM
bbvette69's Avatar
bbvette69
Thanks for the advice,managed to remove them with a few little taps of the hammer.Does it matter if you put them back in the same sides and same position's?
Old Mar 12, 2007 | 04:27 PM
genuine1980's Avatar
genuine1980
IMO... If you had trouble getting them out, then the are worn. You should get new ones. That said, it doesn't really matter which side you put them on or the position.
Old Mar 12, 2007 | 04:29 PM
GTR1999's Avatar
GTR1999
If they are that worn then they should be replaced. If you are rebuilding the posi then the endplay should be .007-.010 when you're done.
To Removing Side Yokes
